Help needed: 2009 Vibe 12V Aux power outlet
Posted: Mon Mar 18, 2013 1:35 pm
by tonycheung
Hi,
I saw a post of wiring the relay so the 12V aux power is always on however it was for the previous generation.
Is there anyone know where is the relay for 2009+ vibe?
Thank you.
Tony
Re: Help needed: 2009 Vibe 12V Aux power outlet
Posted: Mon Apr 15, 2013 12:17 pm
by strangerxp
Vibe 09 pwr dist 1.pdf
(69.53 KiB) Downloaded 390 times
Hello Tony, take a look on the attachments, hope it helps,
Regards, stranger
Posted: Mon Apr 15, 2013 12:19 pm
by strangerxp
Vibe 09 pwr dist 4.pdf
(75.41 KiB) Downloaded 240 times
There is the last two.
Posted: Tue Apr 16, 2013 4:08 am
by beemerphile1
You could disconnect the power wire at the receptacle and run a new (fused) power wire to it.
I chose to keep the stock receptacle switched as it was. I did add 3 always on receptacles and a USB power port. I installed them in the slot below the radio.
I keep a rechargeable trouble light plugged into the switched receptacle. On occasion I have a GPS, satellite radio, radar detector, and cell phone plugged into the added receptacles.
Posted: Tue Apr 30, 2013 7:25 am
by tonycheung
Hi strangerxp,
Thank you for the schematic and I will study it when possible.
cheers,
Tony
Posted: Thu May 02, 2013 5:29 am
In the diagrams that strangerxp posted, 5 shows the lighter (12V outlet). It goes directly to the CIG fuse, and from there to point Q in diagram 3. It works backwards through the accessory relay, which is controlled by the ignition switch. Theoretically you could replace that accessory relay with a jumper wire, but then your radio, amp, and outside mirrors would always have power. Years ago I had a car where the radio wasn't not switched by the key, I recommend against that.
On the 03-08's the cig lighter is wired pretty much the same as in these diagrams. the 03-04's had a second 12V power outlet between the seats, and it is easy to add it to the 05-08's since the wiring is all there. This second outlet is controlled by it's own individual relay, and that 's the one to replace with a jumper to leave the outlet powered on all the time. There is no direct equivalent for the 09-10's, so if you want the lighter outlet to be on all the time, your pretty much need to do as beemerphile1 says, just run a new constant 12V to the lighter.
