Front seat belt buckle
Posted: Wed Feb 27, 2013 7:29 pm
by beclark
My driver's side seat belt buckle has gotten "sticky". My problem comes in ordering the part: is this the "buckle left" or the "buckle right"? (One would assume "left" as the driver's seat is left; but in this case the buckle itself sits to the right of the driver's seat. So...hmm.)
Thanks,
Brian
Re: Front seat belt buckle
Posted: Wed Feb 27, 2013 7:39 pm
Welcome to GenVibe :D I too would assume "left". Did you try cleaning out the latch/buckle assembly yet? Especially if you're a new owner of this Vibe it could have been the victim of a coffee/beverage spill directly over the latch. This is common seeing that our beverages are located in the center console and when you figure a few thousand sips could have led to some spillage :x After time it would "gum up" and become almost inoperable. Things to look at before replacing it. Also post pics of your ride and update profile showing location. Again welcome to GenVibe :D
Posted: Fri Mar 01, 2013 5:15 am
by Doug14
tpollauf wrote: Did you try cleaning out the latch/buckle assembly yet? Especially if you're a new owner of this Vibe it could have been the victim of a coffee/beverage spill directly over the latch. This is common seeing that our beverages are located in the center console and when you figure a few thousand sips could have led to some spillage :x After time it would "gum up" and become almost inoperable.
I too have been the victim of coffee spills, in the seat belt buckles and the down the E-brake abyss.
Posted: Sat Mar 02, 2013 5:52 pm
by beclark
tpollauf wrote: [...] Especially if you're a new owner of this Vibe it could have been the victim of a coffee/beverage spill directly over the latch. This is common seeing that our beverages are located in the center console and when you figure a few thousand sips could have led to some spillage :x After time it would "gum up" and become almost inoperable.
Thanks, I'll attempt a thorough cleaning before I give up an order a new part!
Brian
Posted: Sun Mar 03, 2013 4:16 pm
by vibenvy
According to GMPartsCenter.net, the driver's side is considered the left side and the passenger side is considered the right side.
