Ok to remove PCV valve on a hot engine?
Posted: Wed Jan 23, 2013 6:38 pm
by cptnsolo77
Tomorrow I want to clean it out right after work before it gets dark. Is this something that needs to be done when the engine is cold ? Just like spark plugs ?
Re: Ok to remove PCV valve on a hot engine?
Posted: Thu Jan 24, 2013 6:25 am
by JohnO
No problem doing it while the engine is hot. Just don't burn yourself! (Wear gloves.)
Edit: And be aware that there are two possible part numbers that you could have. It is hard to know ahead of time which one you will have.
