AT Fluid Leak at Drain Plug
Posted: Fri Dec 07, 2012 4:59 pm
I have a 2009 Vibe with the 1.8L engine and Automatic Transmission. I changed the ATF about 5,000 miles ago (using Toyota WS) and while underneath it this afternoon, I noticed a small AT fluid leak bleeding from the drain plug. The plug was tight, so I am wondering if this plug has a washer of some type that would need replacing, or are there other issues I should look for. Thank you in advance for your help.
