Front washer fluid stopped spraying (2009 Vibe)
Posted: Mon Dec 03, 2012 11:31 am
by Sandman
The washer fluid, for the front windshield, stopped working. The rear still works and, yes, the reservoir is full. Any ideas/thoughts?
Re: Front washer fluid stopped spraying (2009 Vibe)
Posted: Mon Dec 03, 2012 11:47 am
by sideshowalan
There is a separate pump for the front and rear washers.
Sounds like the front one died.
Posted: Mon Dec 03, 2012 4:32 pm
by gralm
sideshowalan wrote:There is a separate pump for the front and rear washers.
Fuse?
Posted: Mon Dec 03, 2012 8:34 pm
by star_deceiver
When mine froze up, the back still worked while the front was solid... could be that it's frozen in the line (assuming of course that you live in a colder climate and you have summer fluid).
Posted: Wed Aug 21, 2013 5:51 am
by dallairl
having the very same problem... 2003 vibe. Did ALL vibes has seperate pumps (front and back)?
Posted: Wed Aug 21, 2013 5:13 pm
by sideshowalan
They all have separate pumps.
The 2 pumps are attached directly to the washer fluid reservoir near the bottom. Each with a line going to the front or back.
