				Need new steel wheels
				Posted: Fri Oct 12, 2012 6:47 pm
				by Kelpie
				Hey there,
We have 2 bent rims on our '03 Vibe.  Thought we would get a new set of wheels for it, but really just want some stock wheels.
Any suggestions on where to get them?  All I can find are fancy aluminum wheels.
Thanks,
				Re: Need new steel wheels
				Posted: Fri Oct 12, 2012 6:56 pm
				by trb
				Where are you located?  I have a full set of steel wheels & hubcaps, but shipping would probably run $20 each. You can probably find some close to home on
http://www.car-part.com" onclick="window.open(this.href);return false;  Just look in your state or province, type in your zip code, and look for the 16" x 6-1/2" steel wheels if they are the ones with hubcaps.  You can probably find some for $30-50 each.   Vibe and Matrix wheels will come up.  If you want the alloy wheels, then they are a bit more if you can find them.
There are also a few cars being parted out on here.  Badvibe has a thread on parts and may have some steel wheels.
Good luck!
				Posted: Sat Oct 13, 2012 10:27 am
				by vibenvy
				Also, if you haven't already, check your local Craig's List. I ended up scoring 3 take off steel wheels (less than 1000 miles on them) from a semi-local guy for $75.00 three years ago through Craig's List.
				Posted: Mon Oct 15, 2012 5:59 am
				by Kelpie
				Thanks for the info.  We are located in Indianapolis.
				Posted: Thu Oct 25, 2012 10:49 am
				by sagittarius
				Craigs list ... picked up two sets of steels, one three years ago, and one 6 months ago.   Blizzak WS60 195/60R16 on each Vibe for the 4 winter months.
				Posted: Fri Oct 26, 2012 12:37 pm
				by Kincaid
				Last time I needed a factory steel wheel I contacted a local wrecking yard and it was $30.
