				2003 vibe radio lights not showing
				Posted: Tue Oct 09, 2012 1:02 pm
				by 2003vibeowner
				I have a 2003 Vibe GT. The radio works fine but the display where the time and station show up is not lit. Does anyone know if this could be just a fuse that needs replacing?  Any input would be appreciated. Thank you in advance.
				Re: 2003 vibe radio lights not showing
				Posted: Tue Oct 09, 2012 6:23 pm
				by ramenboy...
				Hey welcome. Post pics of the gt
As far as the radio goes, I believe the display is backlit, so the bulbs are out.
				Posted: Thu Oct 11, 2012 1:26 pm
				by Mariachi
				ramenboy... wrote:Hey welcome. Post pics of the gt
this happened to mine. the lights did go out. that's why i just replaced the factory stereo with a double din.
				Posted: Mon Nov 05, 2012 4:56 am
				by Doug14
				Have had this issue twice, it began to dim on one side then blacked out completely. I tapped it with my finger the first time and it came back on. and the second time it came back on its own after being off for a couple hours. Not sure what happened but give I'd give it a while before you replace it. Mine still works fine
				Posted: Wed Nov 07, 2012 8:20 am
				by leemur
				my 04 was going dim on the right side. then the sound went out on the left and I figured I needed a new radio. Then 2 weeks later i noticed the display was fine, turned it on and the sound was fine also. This was the second stock radio. The fist one was replaced under warrentee for a ground fault. Never really believed that they swapped it.
				Posted: Wed Nov 07, 2012 12:08 pm
				Depending on skill level, you can replace the LCD backlight bulbs in the OEM radio
 viewtopic.php?t=26889" onclick="window.open(this.href);return false;
