light out behind temperature selection knob
Posted: Fri Sep 28, 2012 3:45 pm
by leighangela
It looks like there might be two lights behind the three knobs for the vent, heat and temperature knobs. The knob on the right, the one where you choose how cold or warm you want the air to blow, is not lit up at night. The other two knobs are lit up fine. Is there a way to fix this?
Re: light out behind temperature selection knob
Posted: Sat Sep 29, 2012 8:24 am
by leighangela
So googling this, I found one other person with the same problem. He was told he'd have to replace the whole "A/C control head assembly," but I can't find that part anywhere online. Guess I have to ask a dealer
Posted: Sat Sep 29, 2012 2:15 pm
by Keylies
Look in the HOWTO section I saw a post on that
Posted: Sat Sep 29, 2012 7:43 pm
by ColonelPanic
It doesn't necessarily involve replacing the whole assembly. I did when I had to replace the bulbs in mine, but that was because I broke it trying to get it out.
The bulbs are replaceable on their own, but it is not generally a fun process. Here is a pretty nice writeup:
viewtopic.php?f=28&t=37556&p=420080&#p420080" onclick="window.open(this.href);return false;
Posted: Sun Sep 30, 2012 9:41 pm
by leighangela
Wow, thank you! Too scary for me.
Posted: Sun Sep 30, 2012 9:54 pm
by Flip-Side
I had the exact same issue. I pushed the bulbs back in and they began working again. They were not broken, just unseated.
Posted: Tue Oct 02, 2012 8:13 pm
by leighangela
Flip-Side wrote:I had the exact same issue. I pushed the bulbs back in and they began working again. They were not broken, just unseated.
But you had to pry off the front right? Was it difficult?
Posted: Wed Oct 03, 2012 11:28 am
by FootScoot
I'm having the same annoyance. It worked fine 2 days ago, last night was a no show. Looks strange with just 2 working, and the third one dark. Seems there would be an easier way to fix this than removing the radio and all the surrounding stuff just to reseat or replace a small bulb.
