Strut bar installed Now a couple of questions.
Posted: Thu Jul 17, 2003 12:46 pm
by Celtic_Curse
Well installed freedom design strut bar..as you all know no instructions, so here are a couple of mine since I don't have a clue.1. is it sapposed to be flat or vertical..once you get the the arms over the struts how is it sapposed to sit?2. do you tighten the hinge bolts? the brass bolts that connect the arm to the bar? how tight would you tighten them?3. is the red arms sapposed to sit perfectly flat against the black factory strut rings?any help would be greatly apprecited folks
Re: Strut bar installed Now a couple of questions. (Celtic_Curse)
Posted: Thu Jul 17, 2003 4:14 pm
by celica girl
I thought you were gonna wait for me to help you install the bar???
Posted: Thu Jul 17, 2003 7:36 pm
by cohocarl
Check out this thread, it should answer most of your questions.http://forums.genvibe.com/zerothread?id=4746Mine isn't a Fd. bar, but I did tighten down the end bolts that you are talking about. Here's another link with a pic of the fd. bar.:http://forums.genvibe.com/zerothread?id=816
Re: Strut bar installed Now a couple of questions. (cohocarl)
Posted: Fri Jul 18, 2003 2:39 am
by Celtic_Curse
Thank you, Celica Girl you can still help.
Posted: Fri Jul 18, 2003 2:43 am
by Celtic_Curse
Well I guess I had better take the factory ones off, and redo the install...thanks for the advice.
Posted: Mon Jul 21, 2003 2:58 am
by celica girl
Re: Strut bar installed Now a couple of questions. (celica girl)
Posted: Wed Jul 23, 2003 11:30 am
by Celtic_Curse
Thanks for posting Celica girl! So this isthe way we put it in everyone...we took out the factory rings and just slipped on the new FD bar. We were torn between the vertical or horizontal setup but agreed on horizontal. Driving with the setup in both ways I have to stay the horizontal offered the most responce..thanks for everyones help.
Posted: Wed Jul 23, 2003 6:03 pm
by Geo
quote: Driving with the setup in both ways I have to stay the horizontal offered the most responce..thanks for everyones help. Really now? I might just adjust mine soon, see if it makes even more of a difference :D
Re: Strut bar installed Now a couple of questions. (Geo)
Posted: Thu Jul 24, 2003 4:58 am
by Celtic_Curse
ya, I know it sound wierd but the vertical had a little affect on the cornering, then when we switched it around there's a better feel and cornering, just my two cents try and let me now if its just in my head.
Posted: Fri Jul 25, 2003 5:45 am
by yank dini
this is how I put mine on
Re: Strut bar installed Now a couple of questions. (silverawd26)
Posted: Fri Jul 25, 2003 5:49 am
by yank dini
now I just need the rear
