Missing cargo tie down FOUND!!!
Posted: Tue Jul 15, 2003 10:19 am
by ragingfish
So remember a month or two ago when I lost that plastic retainer clip for a cargo tie down? Then a week later, another retainer and metal screw plate disappeared?Well, I FOUND THEM BOTH.Decided to lift up the rear bench today to see what goodies I found under there. Sure enough, right staring me in the face was the second missing retainer and tie down.Then I thought, I never saw the original one fly out of the car. So maybe it's here. So I peeked under the plastic flaps that stick out below the seatbelt, and sure enough, there wedged under the driver-side rear passenger seatbelt flap was the missing retainer clip! I am whole again!So if you're missing things, and you think they're under the rear bench, they probably are. And don't forget to look here too:
Re: Missing cargo tie down FOUND!!! (ragingfish)
Posted: Tue Jul 15, 2003 12:54 pm
by KSNeptune
Nice find. Way to go. On a related subject, I like to look under things in my wife's altima. She's losing money in there all the time.Is that a speaker in the center? Was there a natural depression there? Does it's sound get muffled by the seat? Is it sit proof?KSNeptune
Re: Missing cargo tie down FOUND!!! (KSNeptune)
Posted: Tue Jul 15, 2003 1:08 pm
by ragingfish
quote:Is that a speaker in the center? Was there a natural depression there? Does it's sound get muffled by the seat? Is it sit proof?Nope, no speaker there. That's a rubber sheet-like seal over some wires that run through the metal and under the car...Everyone's got it...
Re: Missing cargo tie down FOUND!!! (silverawd26)
Posted: Tue Jul 15, 2003 1:13 pm
by ragingfish
Does look like it. Not really sure WHAT it is though...someone with a service manual perhaps?
by millster
Might be for the fuel pump.
Posted: Tue Jul 15, 2003 1:14 pm
by ragingfish
Nah, that goes through the side paneling...and it's only 3 or 4 wires...blinkers and such have dozens...My guess is something with the fuel gauge, since I believe the fuel tank is right below the rear seats?
Posted: Tue Jul 15, 2003 1:15 pm
by millster
quote:My guess is something with the fuel gauge, since I believe the fuel tank is right below the rear seats? I would think that or the pump. I believe you're correct about the location.
Posted: Tue Jul 15, 2003 1:16 pm
by ragingfish
Also possible! I'll IM nova, see what he says...
Posted: Wed Jul 16, 2003 7:24 am
by NovaResource
Yes, that is the access panel for the fuel tank. There are 3 things wired there:1 - Fuel Sender Assembly2 - Fuel Pump (part of the fuel sender assembly)3 - Fuel Tank Pressure (FTP) SenderThe Fuel Sender Assembly contains the following wires in a 5-wire plug (Grey):1 - not used2 - Fuel Gauge (Yellow)3 - Low Fuel Indicator (Brown)4 - Fuel Pump Feed Circuit (Black/Red)5 - Ground (White/Black)Fuel Tank Pressure Sensor is a 3-wire plug (Black):1 - Sensor Ground (Brown)2 - Fuel Tank Pressure Input (Blue)3 - Reference Voltage (Yellow)Is that what wires you see under there?
Re: Missing cargo tie down FOUND!!! (NovaResource)
Posted: Wed Jul 16, 2003 11:52 am
by ragingfish
LOL! Could be! I'll take your word for it!
