04 AWD - Rear cam adjust bolt/nut help
Posted: Wed May 16, 2012 9:54 am
So I managed to break off the nut for the cam adjust bolt on the lower control arm. I was on my way to replacing the hub assembly due to a bad wheel bearing, but I guess I didn't use enough PB Blaster or heat. Question - Is the cam adjust plate (on the nut side) threaded? Is this one piece with the bolt? I need to figure out if I have to cut the bolt out or just grind off the end of the broken bolt and hammer it out. Thanks!
