Foglamp bulb replacement
Posted: Tue Aug 06, 2002 12:41 am
by NSimkins
quote:ullbergm:speaking of foglamps.Has anybody replaced their foglamps with the white or brighter bulbs?The owners manual doesn't say how you are supposed to replace them or what type of bulb..Yes I did replace the foglamp bulbs.Basically what you do is reach your hand under the front facsia near the foglamp. You will feel the foglamp assembly. Basically what you do, if I remember correctly is turn the drivers side assembly counterclockwise and pull out.The passenger side foglamp I believe turns clockwise, then pull out.I will confirm this unless someone else does first. Be careful taking the bulb out not to bang it against any part of the fascia and don't touch the bulb.
[Modified by NSimkins, 11:44 AM 8/6/2002]
Re: Foglamp bulb replacement (NSimkins)
Posted: Tue Aug 06, 2002 1:14 am
by ullbergm
Do you remember what type of bulb it is?If not, thats ok, i can check tonight.
Re: Foglamp bulb replacement (ullbergm)
Posted: Tue Aug 06, 2002 1:16 am
by NSimkins
Here are the bulb numbers. I found these on the matrixvibe.net forum posted by vibedriver:quote:Vibe:One single bulb in the head lamp assembly the 9003 used for both the high & low beam.One bulb in the fog lamp assembly the 9006. Total of only 4 bulbs is needed to do the whole system... Hope this helps.
Posted: Tue Aug 06, 2002 1:22 am
by ullbergm
Great thanks.
