Need a new catalytic converter will this work?
Posted: Sun Feb 19, 2012 2:59 am
by Jeremy_K
I have an 03 Vibe AWD that needs a new cat. I was wondering if This replacement would work? I have friends that could weld it in. Would I need any other parts i.e. gaskets, clamps, etc.?
http://www.ebay.com/itm/Magnaf..._1344
Re: Need a new catalytic converter will this work? (Jeremy_K)
Posted: Sun Feb 19, 2012 5:41 am
by DiveNut
You'd need to cut the flange off the old Cat and weld it to the new one. Other than that. Nope. Though may want to replace the donut/gasket on the flange.Pat
Posted: Sun Feb 19, 2012 8:42 am
by rAERRK
yes it will work and that's a damn good price
Posted: Sun Feb 19, 2012 8:57 am
by 04shadowvibe
jeremy k, i know this is not about the cat but i have a question about when you did your rear axle seals....just trying to get a hold of you..thanks
Re: (04shadowvibe)
Posted: Mon Feb 20, 2012 8:05 am
by Jeremy_K
I bought the seals and the tools to do the job. That's as far as I got
Re: (Jeremy_K)
Posted: Mon Feb 20, 2012 1:50 pm
by 04shadowvibe
oh its a blast to do, my lower a-arm to spindle bolts are seezed into the bushings, chances are from road salt. I got one axle shaft to pop out and they really come out easy. If your bolts come out its not too bad of a job.I wanted to pick your brain to see if you had this trouble but i guess not yet since you didnt start. I am working on a how to write up for it for others that have to do this repair.
Posted: Tue Feb 21, 2012 10:12 am
by MrsSlocum
When mine went out last year, I paid $760 to replace it. Good luck!
