To ground or positive?
Posted: Sun Jan 08, 2012 8:23 am
				I found the wiring diagram for the turn signal/fog light switch (AllData) fog light wire #4 postion on the connector. Question is....... if I'm just wanting to and a switch (using factory wiring for adding fogs) one side would go to the fog light wire would the other side go to ground or to a positive?  I know I'll need the relay also.        Thanks much
