Off Idle Hesitation (cold)
Posted: Mon Dec 26, 2011 1:34 pm
by fiveoh
Hello.I searched the forums but didn't find much info.I have a 2007 base Vibe (auto) with less than 30k miles.When I start in the morning and initially drive off, all is normal. The first time I slow down to 'stop' (or very slow roll) and go to accelerate again.........I press on the accelerator and NOTHING for a full 1-2 seconds....* It doesn't shut off* It doesn't idle roughlyIt just doesn't go......engine RPM's around idle speed and don't increase...If I release the accelerator pedal and then get back on it, it goes fine and doesn't do it anymore (for now). Anyone else experience anything like this? Thanks,
Posted: Tue Dec 27, 2011 2:24 pm
by Salsa Guy
DId you have the ECU/PCM replaced? That year car has drive by wire maybe you have some condensation in the Throttle control connector.
Re: Off Idle Hesitation (fiveoh)
Posted: Wed Jan 18, 2012 3:34 am
by sideshowalan
Try and reset the DBW system.http://forums.genvibe.com/zerothread?id=252381: turn key to "on" (not to "start," you do not want it running)2: push pedal all the way to the floor and hold it there3: wait 5 seconds4: turn key to "off" while still holding pedal5: remove foot off the gas pedal then start the car....enjoy !!!
Re: Off Idle Hesitation (sideshowalan)
Posted: Wed Jan 18, 2012 3:51 am
by trb
Good info to know about the DBW systems. I'm not used to all the electronics controlling everything, but they have good points and a few bad ones.Nelson, off topic, but do you have any pics of your 5.0 LX?
