06 AWD rear diff seal leak again, part #s needed
Posted: Sat Dec 24, 2011 4:57 am
by 04shadowvibe
Well the rear diff oil seals are leaking again on the vibe. Had them replaced around 30k at a dealer and when the car came back the new seals were leaking worse, so they were replaced again. Now at about 70k one seal is leaking badly. I would rather not take it to the dealer a half hour away and fix it myself, i have the mechanical ability to do so. Anyone know where i can get the seals and what the part number is? i have had no luck finding them online.
Re: 06 AWD rear diff seal leak again, part #s needed (04shadowvibe)
Posted: Sat Dec 24, 2011 12:08 pm
by cq358
is it likey they over filled the diff.?
Posted: Sat Dec 24, 2011 1:22 pm
by star_deceiver
If you have the old seals take one to an industrial supply store that specializes in bearings. The Toyota dealer can order them for you.
Posted: Sun Dec 25, 2011 8:04 am
by 04shadowvibe
well looks like i will hit the toyota dealer, want to have the new parts before i disassemble the car. im positive its not over filled, it was not leaking for about 30k then started a slow leak that has only got worse. It leaked enough to completely drain the rear diff a few times now and i have been refilling it monthly now.
Posted: Sun Dec 25, 2011 2:58 pm
by 04shadowvibe
well looking deeper on genvibe i was able to find the toyota and gm part numbers and online sites to order them.GM **969361(old) SEAL DIFF CARR OIL,(PART OF 9,36),(42MM ID, 65MM OD),(15.5MM THICK)Replaced by: **2053502needed - 03-06 -$19.35eaToyota 90311-42033 (old) SEAL, OIL (FOR REAR DIFFERENTIAL SIDE GEAR SHAFT)Replaced by: 90311-42046 2needed $7.36ea I think i will be ordering the toyota ones.http://www.toyotapartszone.com...=true
Posted: Fri Jan 06, 2012 11:38 am
by cq358
opps
