				cruise lite blinks cruise will not engage again
				Posted: Sat Oct 08, 2011 9:23 am
				by jmsgrieves
				While driving with cruise on, but not engaged, lite starts to blink, and  cruise will not engage unless turned off and then back on. this started recently, any ideas?
				Posted: Sat Oct 08, 2011 10:48 am
				by jimincalif
				My Lexus did this recently, after having the brake light switch replaced. Turned out the replacement brake light switch was defective.  The CC has to have a circuit thru the brake light system so that it will disengage when the brakes are applied.   Check to see that all of your brake lights are working, in researching this I found out that even burned out lights can confuse the CC.Both the Vibe and Lexus are Toyota, I would imagine the CC system is pretty much the same.
				Re: cruise lite blinks cruise will not engage again (jmsgrieves)
				Posted: Wed Oct 12, 2011 11:16 pm
				by joshuaeb09
				It could also be a speed sensor thing.  I know that if you have VSC it should have a speed sensors at every wheel.  I know that my Cruise has the same weirdness, but that's due to the fact that I removed the governor via the unichip which basically tricks the speed senors.
