Reading/Map Light
Posted: Thu Oct 06, 2011 8:35 am
by Gorjes
I have a 2003 GT. The Reading light up by the moonroof controls burnt out? I cant find anything in the manual about it, except how to turn it on/off. Any idea how to get to it or what bulb it takes? Thanks in advance
Re: Reading/Map Light (Gorjes)
Posted: Sat Oct 08, 2011 8:39 am
it's a #1895 bulbTo get to it, you have to remove the one screw you can see on the cover, then pry/pull the whole cover off. Don't try to take off just the clear plasticon mine, I rarely use it and sometimes it won't come on, but if I hit the switch on and off enough times, it starts to work. Might worth trying a hundred cycles on the switch to see if that cleans it up before buying a replacement bulb
Posted: Sun Oct 09, 2011 7:59 am
by cptnsolo77
I have searched high & low for this particular bulb. Local auto parts stores dont carry it. I have tried ebay but cannot find a correct match. The wattage always seems to be off. Any suggestions?
Re: (cptnsolo77)
Posted: Sun Oct 09, 2011 8:04 am
by KITT222
Go for an LED one. I went full-LED on my interior lights and it lights up the night. Just plug and play. Although the dummy plug I had to go into the spot where the bulb went did have the polarity wrong, so I had to switch the wires, but that might be seller-specific. They're all over ebay. I didn't get bulb-specific ones, they just sent me the LEDs and dummy bulbs.
Re: (KITT222)
Posted: Mon Oct 10, 2011 2:46 am
by cptnsolo77
Thanks for the advice. How much did you pay for the map light?
Re: (cptnsolo77)
Posted: Mon Oct 24, 2011 7:57 am
by Gorjes
Thank you so much for the bulb # and the pic and play by play! (Much needed . It was burnt out. For anyone else, they have the bulbs at Advance Auto Parts. Thanks again
