ABS
Posted: Sun Sep 04, 2011 12:03 pm
by Nitr0
I have ABS and I really dont like it, I like having full control of the brakes, is there a way to get rid of the abs equipment? maybe it seems alittle weird to get rid of it but after having my 90 Mustang GT without ABS and drivin in iowa winters and not havin problems it just seems useless and lazy to have it
Re: ABS (Nitr0)
Posted: Sun Sep 04, 2011 7:19 pm
by djkeev
How do you drive?!?ABS only activates in a panic, lock the wheels up situation (or wet roads and ice when the pavement is very slippery and wheels tend to slide easily).I have an 07 Vibe, drive all year, including icy winters and wet roads, and in four years can count on one hand the number of time that ABS has activated.You might consider getting the unit checked out? If it is fine, consider how aggressively you brake and drive and make some modifications.FYI, ABS is a time proven life saver in panic situations. It will control your car better than you can, bringing it to a fast straight line stop and not skid out of control.You can disable most ABS systems but you didn't tell us what you are driving. It is also short sighted and foolish to disable it as well. Sorry to tell you but in this instance, the machine is better than the human.....any human!Dave
Re: ABS (djkeev)
Posted: Sun Sep 04, 2011 11:01 pm
by DiveNut
Ya, I would agree. ABS was the only option I required when shopping for my Vibe. Like djkeev, have not been in many emergency/panic braking situations in the last 7 years, but it proved very helpful the few time when I did need to. Just my two cents.
Posted: Mon Sep 05, 2011 1:40 am
by Nitr0
I have an 04 AWD, I didnt know it just came on under hard braking conditions, it rattles at low speed and is choppy braking at low speed, I looked at everything checked the rotors on a flat surface and they arent warped unless they are a tiny bit, the last thing I wanted to check before a mechanic was the abs
Re: ABS (djkeev)
Posted: Mon Sep 05, 2011 2:40 am
by Houston
Re: (Nitr0)
Posted: Mon Sep 05, 2011 3:07 am
by djkeev
Quote, originally posted by Nitr0 »I have an 04 AWD, I didnt know it just came on under hard braking conditions, it rattles at low speed and is choppy braking at low speed, I looked at everything checked the rotors on a flat surface and they arent warped unless they are a tiny bit, the last thing I wanted to check before a mechanic was the abs There is a whole diagnostic procedure for ABS, some of it electronic using a diagnostic computer. I'm not sure of the 04's about exactly what on board diagnostics you may have but I know the 07's are fairly extensive.You've got problems with the system if it is acting up as you say. It is NOT normal at all.Please post what you find the problem is to help others with similar issues.Good LuckDave
Re: (djkeev)
Posted: Mon Sep 05, 2011 3:55 pm
by star_deceiver
I find if I go around a sharp corner at a high rate of speed the abs will come on if I even touch the brakes... mind you the VSC would have kicked in long before that (but I never drive with it active)... this usually happens when I take a freeway entrance ramp with spirit (shall we say)!You could always just pull the fuse to the ABS system.
Re: (star_deceiver)
Posted: Tue Sep 06, 2011 10:42 am
by djkeev
Quote, originally posted by star_deceiver »........You could always just pull the fuse to the ABS system.Yes, that may work but which of the related items on the fuse do you decide you no longer need as well??Fuse 20......Stoplamps, Center High-Mounted Stoplamps (CHMSL),ABS, Vehicle Stability Control System, Multiport Fuel Injection System/Sequential Multiport Fuel Injection System,Brake Transmission Shift InterlockDave
