P0505 after CAI install
Posted: Tue Aug 09, 2011 12:53 am
by hapagan
I installed my new CAI 2 days ago and the car ran fine for thos 2 days. This morning i ran the car and the engine light came on. When i read the code it showed a P0505. So i did some research and found out it could be a dirty TB or IAC valve. Now all of this was fine before the CAI, could it possibly be something else? Idd appreciate anyone's help. Thnx
Re: P0505 after CAI install (hapagan)
Posted: Tue Aug 09, 2011 4:55 am
by star_deceiver
Increased airflow. Take out the TB and IAC and clean them, then see what happens. Does the CAI have an oiled filter?
Posted: Tue Aug 09, 2011 6:46 am
by hapagan
The CAI has an AEM dry-flo filter. it was the CAI and Filter that were in Housofbugs vibe.
Posted: Tue Aug 09, 2011 10:14 am
does it idle ok?Check to make sure all the vacuum hoses are connected and connected correctly
Re: (hapagan)
Posted: Tue Aug 09, 2011 10:15 am
by vibenvy
Quote, originally posted by star_deceiver »Increased airflow. Take out the TB and IAC and clean them, then see what happens.I agree. I'd start with this. Also, did you disconnect the negative battery cable before you installed the CAI?Quote, originally posted by hapagan »The CAI has an AEM dry-flo filter. it was the CAI and Filter that were in Housofbugs vibe.I know Tim took great care of his Vibe and everything on it. Didn't the filter even have a hydro shield on it?
Posted: Tue Aug 09, 2011 10:30 am
by MotoAce51
Have the code reset and see what happens. When I first installed the CAI I tripped the light, had it reset and it didnt come back on. Same thing happened with the TB spacer. Light came on, had it reset, never came back on...
Posted: Tue Aug 09, 2011 11:58 am
by hapagan
it is idling normally so i just reseted the code for now untill i get payed and can buy a cleaner for the TB and IAC. yes Tim did have a hydro shield on it but he didnt sell it. it might have gotten damaged on the accident.
Posted: Wed Aug 10, 2011 11:35 am
by hapagan
ok so i still havent gotten payed so i havent cleaned the IAC or the TB but after erasing the codes from the computer today i got the same one + a new one. today i got the P0446. it said it was Evaporative Emission System Vent Control Circuit. should i be worried ?
Re: (hapagan)
Posted: Wed Aug 10, 2011 12:28 pm
by star_deceiver
That sounds like a vacuum line wasn't plugged back in.
Posted: Wed Aug 10, 2011 12:44 pm
by hapagan
all lines were plugged back in tho. unless i plugged one in wrong (or two if i got them mixed up). ill post a close up of the connections in a couple of min.
Posted: Wed Aug 10, 2011 12:53 pm
by hapagan
ok here are some pics. here is the TB hose and the MAFand then here are the other two hoses which i unplugged thinking i had to in order to install the CAI (i think these might be reversed or something. im starting to regret this CAI install :/
Re: (hapagan)
Posted: Wed Aug 10, 2011 1:28 pm
by star_deceiver
It's just a bug or two, once it's sorted out you're going to love it!!!
Posted: Wed Aug 10, 2011 8:20 pm
by MotoAce51
Make sure the MAF is connected well. If there is an air leak it will trip a code. I will shoot some pics of my install after work so you can check the hoses if someone else doesnt before then.
Re: (hapagan)
Posted: Wed Aug 10, 2011 11:56 pm
Is the hose between the PCV and throttle body still connected , or does that change with a CAI install?
Posted: Thu Aug 11, 2011 6:58 am
by hapagan
im not really sure if that setup is correct. it might be wrong before installing i unplugged all the hoses and didnt keep track of where they went
Posted: Thu Aug 11, 2011 9:02 am
by MotoAce51
It looks like the hoses are hooked up wrong. I will add some pics here in a few. I am pretty sure this is your issues....Pardon the dirty engine bay but here you go...This is where I see the issue:This line in your picture goes to the little valve block thing, and the big hose from under the cover goes here. Switch these 2 lines....
Posted: Thu Aug 11, 2011 11:02 am
by hapagan
figures! lol yeah they are switched. ok thnx a lot. ill go and fix it right now and give feedback later.
Posted: Fri Aug 12, 2011 6:28 am
by hapagan
everything good now thnx a lot guys!
Posted: Fri Aug 12, 2011 7:14 am
by MotoAce51
Glad you got it now. How's it feel/ sound/ mileage?
Posted: Fri Aug 12, 2011 11:19 am
by hapagan
feels and sounds great. MPG ill have to let you know. havnt run a full tank yet.
Posted: Fri Aug 12, 2011 11:55 am
by MotoAce51
Next you will need the TB spacer. It sucks needing to cut down the CAI but it sounds even better. Sometimes it even seems to sound like a blow off valve
Posted: Fri Aug 12, 2011 12:10 pm
by hapagan
yeah i dont think ill be getting anything else for my car. i might even be selling it. :/ i now why install a CAI if im gonna sell it? well i wasnt planing on selling it when i got the CAI but i found a good deal on on 2002 GTI VR6 i might get on that
