P0505 after CAI install
hapagan
Post by hapagan »
I installed my new CAI 2 days ago and the car ran fine for thos 2 days. This morning i ran the car and the engine light came on. When i read the code it showed a P0505. So i did some research and found out it could be a dirty TB or IAC valve. Now all of this was fine before the CAI, could it possibly be something else? Idd appreciate anyone's help. Thnx
04 Pontiac Vibe Gray, M+T package Custom Front Bumper Paint5% window tint everywhere except three front windows 12" Pioneer IMPP subPro bend bandpass boxBoss 1600w 4Ch amp6, 6.5 Infinity Kappa 62.9i 450w each
Re: P0505 after CAI install (hapagan)
Increased airflow. Take out the TB and IAC and clean them, then see what happens. Does the CAI have an oiled filter?
hapagan
Post by hapagan »
The CAI has an AEM dry-flo filter. it was the CAI and Filter that were in Housofbugs vibe.
does it idle ok?Check to make sure all the vacuum hoses are connected and connected correctly
Re: (hapagan)
Quote, originally posted by star_deceiver »Increased airflow. Take out the TB and IAC and clean them, then see what happens.I agree. I'd start with this. Also, did you disconnect the negative battery cable before you installed the CAI?Quote, originally posted by hapagan »The CAI has an AEM dry-flo filter. it was the CAI and Filter that were in Housofbugs vibe.I know Tim took great care of his Vibe and everything on it. Didn't the filter even have a hydro shield on it?
MotoAce51
Post by MotoAce51 »
Have the code reset and see what happens. When I first installed the CAI I tripped the light, had it reset and it didnt come back on. Same thing happened with the TB spacer. Light came on, had it reset, never came back on...
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
hapagan
Post by hapagan »
it is idling normally so i just reseted the code for now untill i get payed and can buy a cleaner for the TB and IAC. yes Tim did have a hydro shield on it but he didnt sell it. it might have gotten damaged on the accident.
hapagan
Post by hapagan »
ok so i still havent gotten payed so i havent cleaned the IAC or the TB but after erasing the codes from the computer today i got the same one + a new one. today i got the P0446. it said it was Evaporative Emission System Vent Control Circuit. should i be worried ?
Re: (hapagan)
That sounds like a vacuum line wasn't plugged back in.
hapagan
Post by hapagan »
all lines were plugged back in tho. unless i plugged one in wrong (or two if i got them mixed up). ill post a close up of the connections in a couple of min.
hapagan
Post by hapagan »
ok here are some pics. here is the TB hose and the MAFand then here are the other two hoses which i unplugged thinking i had to in order to install the CAI (i think these might be reversed or something. im starting to regret this CAI install :/
Re: (hapagan)
It's just a bug or two, once it's sorted out you're going to love it!!!
MotoAce51
Post by MotoAce51 »
Make sure the MAF is connected well. If there is an air leak it will trip a code. I will shoot some pics of my install after work so you can check the hoses if someone else doesnt before then.
Re: (hapagan)
Is the hose between the PCV and throttle body still connected , or does that change with a CAI install?
hapagan
Post by hapagan »
im not really sure if that setup is correct. it might be wrong before installing i unplugged all the hoses and didnt keep track of where they went
MotoAce51
Post by MotoAce51 »
It looks like the hoses are hooked up wrong. I will add some pics here in a few. I am pretty sure this is your issues....Pardon the dirty engine bay but here you go...This is where I see the issue:This line in your picture goes to the little valve block thing, and the big hose from under the cover goes here. Switch these 2 lines....
hapagan
Post by hapagan »
figures! lol yeah they are switched. ok thnx a lot. ill go and fix it right now and give feedback later.
hapagan
Post by hapagan »
everything good now thnx a lot guys!
MotoAce51
Post by MotoAce51 »
Glad you got it now. How's it feel/ sound/ mileage?
hapagan
Post by hapagan »
feels and sounds great. MPG ill have to let you know. havnt run a full tank yet.
MotoAce51
Post by MotoAce51 »
Next you will need the TB spacer. It sucks needing to cut down the CAI but it sounds even better. Sometimes it even seems to sound like a blow off valve
hapagan
Post by hapagan »
yeah i dont think ill be getting anything else for my car. i might even be selling it. :/ i now why install a CAI if im gonna sell it? well i wasnt planing on selling it when i got the CAI but i found a good deal on on 2002 GTI VR6 i might get on that
