Tweeter Mounting
Posted: Mon Aug 01, 2011 7:23 am
by MotoAce51
This is for anyone who has mounted aftermarket tweeters in the stock location. How did you mount the tweeters? I have everything hooked up and ready to go but I cant seem to get enough room for the larger tweeter. I tried to search but all I can find are mounting for tweeters in the non moon & tunes. I would like to use the stock location while utilizing the factory look. Any info would be greatly appreciated.
Re: Tweeter Mounting (MotoAce51)
Posted: Mon Aug 01, 2011 11:07 am
by KITT222
My dad and I just used the bracket which it came with, and snapped off all the little tabs on the tweeter. The cover fit right back on perfectly.
Posted: Mon Aug 01, 2011 11:25 am
by A Psycho Martyr
like you said...I used the NON m&t thingy and mounted tweeters in it.Size wasn't an issue for me (no pun intended...hehe)
Re: Tweeter Mounting (A Psycho Martyr)
Posted: Sat Aug 27, 2011 9:12 pm
by DoubleBaril
Quote, originally posted by A Psycho Martyr »like you said...I used the NON m&t thingy and mounted tweeters in it.Size wasn't an issue for me (no pun intended...hehe) Did the same; Went to an auto wrecker and picked up the non M&T pieces for a couple bucks, and drilled holes in them to mount the new tweeter
Posted: Sun Aug 28, 2011 10:07 am
by A Psycho Martyr
That might be your best bet if your new tweeters don't fit in the m&t housings
Posted: Mon Aug 29, 2011 4:30 am
by audiovibe
When I did a friend of a friends Vibe, I removed the grill on the stock sail panel drilled out the hole for the new tweeter. I then used automotive grade hot glue to secure the tweeter from behind and re attached the stock grill. Snapped it all back together. The tweeters never came lose after 3 years of their ownership
