viper 5901 alarm/remote start install help plss!!!
Posted: Tue May 10, 2011 9:16 am
by Krystian
hey guys i have a 2003 pontiac vibe automatic transmission i pretty much got it in there except for the ignition wires im not sure how they are supposed to be ive been reading alot and still cant figure it out an anyone give me a detailed description of where i hook up the starter wires,ignition wires, how do i hook up the wires to the ignition harness???????? do i needa bypass somehow??? anything im missing.....??
Re: viper 5901 alarm/remote start install help plss!!! (Krystian)
Posted: Tue May 10, 2011 10:45 am
by MotoAce51
If I remember correctly my grand am was just spliced into the wires. I think it was yellow. But again, thats the grand am not the vibe.
Posted: Tue May 10, 2011 11:35 am
by jayman2009
ill try to take a look at mine tommrow as i have almost the same alarm in mine
Re: (jayman2009)
Posted: Wed May 11, 2011 1:13 am
by Krystian
yes pls pls do my cars sitting till i get it hooked up take some pics if you may
Posted: Wed May 11, 2011 1:58 am
by keithvibe
you can download the service manual for the matrix and use that to find the right wire you need to connect to.
http://pdftown.com/PDF-Toyota-....html
Re: viper 5901 alarm/remote start install help plss!!! (keithvibe)
Posted: Wed May 11, 2011 2:59 am
by Krystian
idk man maybe thi will help u guys help me i have an 03 vibe auto transheres the 10 wires i need to connect PINK(+) IGNITION 1 INPUT/OUTPUTH3/2RED/WHITE(+) FUSED (30A) IGNITION 2 / FLEX RELAY INPUT 87H3/3ORANGE(+) ACCESSORY OUTPUTH3/4VIOLET(+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)H3/5GREEN(+) STARTER INPUT (KEY SIDE OF THE STARTER KILL WIRE)H3/6RED(+) FUSED (30A) IGNITION 1 INPUTH3/7PINK/WHITE(+) IGNITION 2 / FLEX RELAY OUTPUTH3/8PINK/BLACK(+) FLEX RELAY INPUT 87A key side (if required) of FLEX RELAYH3/9RED/BLACK(+) FUSED (30A) ACCESSORY/STARTER INPUTH3/10NC (no connec- tion)NCwhere exatly would i conne t each one of them if i connect them at all..
Posted: Wed May 11, 2011 9:57 am
by Sublimewind
THis is why in my 15 or so years of car audio, I've never done an alarm... Pure headache..
Re: (Sublimewind)
Posted: Wed May 11, 2011 10:02 am
by Krystian
tell me about it... 3 days and still cannot come up with the solution
Posted: Thu May 12, 2011 9:12 am
by audiovibe
These are for the alarmPINK------Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS RED/WHITE-----Ignition 2 BLACK/YELLOW (+) IGNITION SWITCH HARNESS ORANGE-----Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS VIOLET-----Starter 1 RED (+) IGNITION SWITCH HARNESS(CAR SIDE OF THE STARTER KILL)GREEN-----Starter 1 RED (+) IGNITION SWITCH HARNESS(KEY SIDE OF THE STARTER KILL WIRE)These are for the Remote startRED------Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESSPINK/WHITE-----Ignition 2 BLACK/YELLOW (+) IGNITION SWITCH HARNESSPINK/BLACK-----Ignition 1 BLACK/WHITE (+) IGNITION SWITCH HARNESS RED/BLACK-----Accessory 1 BLUE/RED (+) IGNITION SWITCH HARNESS The starter wire will need to be cut in half. the side going to the ignition switch will be the key side, the wire that will be going to the car will be the starter side. Please test all wires with a test light or a multi-meter prior to hook up. it has been a while since I've done a remote start or alarm.
Re: viper 5901 alarm/remote start install help plss!!! (audiovibe)
Posted: Sat May 14, 2011 4:47 pm
by Krystian
man this **** is getting to me here are all the wires and where i hooked them up please tell me where i went wrong.... ty Just copy and paste what you think should work. thx lol i bet im missing alot lol or just a little dumb mistake lol.Main Harness (H1) 12 pin connectorH1/1 Red/White (-)200mA Aux/Trunk ---------- Not connectedH1/2 Red (+) 12VDC Constant Input ----------- 12 V White & black (IGN Harn)H1/3 Brown (+) Siren Output ------------------- Siren (+)H1/4 White/Brown -Parking light isolation ----- Not ConnectedH1/5 Black (-) Ground -------------------------- Ground at driver kick panel boltH1/6 Violet (+) Door Trigger Input ------------- Not connectedH1/7 Blue (-) Trunk Pin -------------------------- Not ConnectedH1/8 Green (-) Door Trigger Input ------------ Red/White(-)Interior light SwitchH1/9 Blck/White(-)200mA Dome light output-- Not ConnectedH1/10 White/Blue(-) Remote start/turbotimer input-------Not connectedH1/11 White ----Parking light output--------------Not ConnectedH1/12 Orange (-) 500ma Ground when armed----Not Connected H2 Harness 18-Pin ConnectorH2/1 Light Green/Black (-) 200mA OEM Alarm disarm Output -- Not ConnectedH2/2 Orange/Black (-) 200mA Aux 4 output ---------------------Not ConnectedH2/3 Green/White (-) 200 mA OEM Alarm Arm Output---------- Not NonnctedH2/4 Violet/Black (-) 200mA Aux 2 output ------------------------Not ConnectedH2/5 White/Black (-) 200mA Aux 3 output ------------------------Not ConnectedH2/6 White/Violet (-) 200mA Aux 1 output ------------------------Not ConnectedH2/7 Grey/Black (-) Diesel wait to start----------------------------Not ConnectedH2/8 Brown/Black (-) 200mA Horn Honk Output ------GreenYellow(-)@Steering H2/9 Violet/White--- Tachometer Input ------------------------white @ ignition coilH2/10 Dark Blue (-) 200mA Status Output----------------------Not ConnectedH2/11 Pink/White (-) 200mA Flex Relay Control Output--------Not ConnectedH2/12 Orange (-) 200mA Accessory Output----------------------Not ConnectedH2/13 Purple (-) 200mA Stater Output----------------------Not ConnectedH2/14 Pink (-) 200mA Ignition 1 Output----------------------Not ConnectedH2/15 Grey (-) Hood Pin Input (NC or NO) ---------------------- Hood PinH2/16 Blue/White (-) 200mA 2nd Status Output/rear Defogg----Not ConnectedH2/17 Brown (+) Brake Shutdown Input---------------H2/18 Black/White (-) Neutral Safety Input----------------------Not ConnectedDoor Lock 3-pin Connector 1-Blue (-) 500mA Unlock OutPut----------------- Blue/Yellow (Driver Kick Panel)2-Empty----------------------------------------------------------------------------------3-Green (-) 500mA Lock OutPut ------------------Green (Driver Kick Panel)Remote Start (H3) 10-Pin ConnectorH3/1 Pink (+)Ignition 1 Input/Output-- Ignition 1 Black/White(+)Ignition HarnessH3/2 Red/White (+) (87) Flex Relay Input (30A Fused)--- Ign 2 (Black/yellow)H3/3 Orange (+) Accessory Output ------------------------ Blue/Red (Ign Harness)H3/4 Violet (+) Starter OutPut -----------Red starter wire car side (Ign Harness)H3/5 Green (+) Starter Input ------------Red starter Wire Key side (Ign Harness)H3/6 Red (+) Ignition 1 Input (30A Fused) ------------ Ign 1 Black/WhiteH3/7 Pink/white (+) Flex Relay Output -------------------ign 2. Black/yellowH3/8 Pink/Black (+) Flex relay input ----------------------ign 1. black/whiteH3/9 Red/Black (+) Acc/Starter Relay input (30A Fused) -accessory red/ blue
Posted: Sun May 15, 2011 1:57 am
by audiovibe
Quote, originally posted by Krystian »H1/2 Red (+) 12VDC Constant InputH2/17 Brown (+) Brake Shutdown Input--------------- This wire needs to go to the battery as it needs to be hot at all times.The brake input also has to be wired.
Posted: Sun May 15, 2011 2:20 am
by Krystian
the brake is wired but ill try hooking it to the battery
Posted: Mon May 16, 2011 1:06 pm
by Krystian
still dosent work man idk (removed)... (removed)
Posted: Tue May 17, 2011 4:42 am
by audiovibe
Could be any number of things, my advise would be to take it to a pro. to hard to trouble shoot through the net.Sorry
