Front suspension arm (control arm) problem
Posted: Sat May 07, 2011 9:56 am
by plausipo
Vibe 2004 went to garage and the mechanics observe cracks in this plastic part (cicled in red)It would require replacing the whole front suspension arm sub-assy.1) Is immediate repair needed, or it can wait for several months?2) The following supplies this part: Mevotech, Raybestos, Dorman, Deeza and ACDELCO, which one is more durable?Thanks for your input
Re: Front suspension arm (control arm) problem (plausipo)
Posted: Sun May 08, 2011 12:36 pm
by star_deceiver
Just the plastic/rubber or is the control arm itself cracked? Pics?
Posted: Sun May 08, 2011 9:18 pm
by plausipo
Just the plastic/rubber...not the control arm
Re: (plausipo)
Posted: Mon May 09, 2011 3:21 am
by star_deceiver
Is there movement in the control arm? Are the bolts tight? Rubber components degrade over time but so long as they're tight and inplace it shouldn't be too much of a concern. But if there's movement up/down or side to side I'd get it fixed. Check the other components on the control arm as well, you may want to have them replaced on both sides since the contol arm will be partially removes to do the work.
Posted: Mon May 09, 2011 9:28 pm
by plausipo
I don't feel the swaying when stopping that people talk about. Sometimes, it does rumble like train going through sleepers on track.
