Instrument Cluster Swap?
Posted: Wed May 04, 2011 10:19 pm
by DressedInBlack
How hard would it be to swap and retrofit an 08 instrument cluster into an 09?I know this wouldn't be a direct fit and the process would require some inventive mounting, but what would be involved in the electronic end of the project? Would I be rewiring the entire thing or just matching a few connectors?I would mainly want this done because I like the 08 style better than what I have now. If the swap would be too much of a pita, ill look into some custom faceplate options.
Posted: Wed May 04, 2011 10:31 pm
by Sublimewind
Could be simply a PNP thing..Could be a complete nightmare.. Maybe you get to be the first to find out.. cause I doubt anyone else has done it...
Re: (Sublimewind)
Posted: Thu May 05, 2011 1:45 am
by DressedInBlack
Quote, originally posted by Sublimewind »Could be simply a PNP thing..Could be a complete nightmare.. Maybe you get to be the first to find out.. cause I doubt anyone else has done it... im hoping for the first, expecting the second, and pretty sure on the third.
Re: (DressedInBlack)
Posted: Thu May 05, 2011 2:38 am
by lovemyraffe
My guess is that it might PNP, but will it fit properly?
Re: (lovemyraffe)
Posted: Thu May 05, 2011 7:17 am
by vibenvy
Quote, originally posted by DressedInBlack »I would mainly want this done because I like the 08 style better than what I have now. If the swap would be too much of a pita, ill look into some custom faceplate options.If you end up deciding to look into custom gauge overlays, I would recommend contacting Black Cat Custom. They do some amazing things with gauges .
