blinker / hazzard light relay
Posted: Sun Apr 17, 2011 2:24 am
by northvibe
So has anyone ever replaced theirs? is it in the headlight relay or its own? I cant find a turn signal relay itself but I can find headlight ones.I suppose I should add info in. My sister has my vibe. She was driving, went to use a turn signal, heard a "clunk" like noise. Now the turn signals and hazards do not work. The fuse looks good, but theres a relay for it on the drivers side of the dash. Sounds like a good 1st thing to try fixing is the relay...
Posted: Sun Apr 17, 2011 6:30 am
by Sublimewind
Haven't replaced on in a vibe, but should be a PNP part.. just swap.. whe you find it, there should be another like it you can swap and test, just to make sure..
Re: blinker / hazzard light relay (northvibe)
Posted: Sun Apr 17, 2011 8:50 am
by lovemyraffe
I've replaced it in my Vibe. It's behind the dimmer dial. It's kinda a pain in the (removed) to do. It is just for the turn signals/hazards.
Posted: Sun Apr 17, 2011 10:23 am
by northvibe
ok ill let my dad know. I have no idea what he is looking at.... is this the $60 one? the same as the headlight relay, model wise?
Re: (northvibe)
Posted: Mon Apr 18, 2011 9:48 am
by lovemyraffe
I thought it was different than the headlight relay, but I could be wrong.
Posted: Mon Apr 25, 2011 3:01 am
by northvibe
turns out, the relay was not pushed in all the way. My dad looked at it, ordered the part then went to take out the old one (in the fuse box on the driverside inside the cabin, left side of the console thing) and found it was half way out. Pushed it in, all is working...huh weird.
