Squealing Belt
Posted: Wed Apr 06, 2011 10:41 pm
by NascarXprt
recently i had my serpentine belt replaced around the end of last year, and just a month ago, my sister noticed a weird rattling noise coming from the engine and now its gotten worse. i was able to narrow the noise down to the Serpentine belt area. and just last night it started to squeal and just a few minutes ago it (the belt) started to cause the car to start overheating.so any ideas on what might be causing this issue?
Re: Squealing Belt (NascarXprt)
Posted: Wed Apr 06, 2011 11:26 pm
by BlueCrush
Belt tensioner pulley = rattlingFix: Replace pistonBelt squealingFix: Gatorback beltOverheatingFix: ??
Re: Squealing Belt (BlueCrush)
Posted: Wed Apr 06, 2011 11:36 pm
by NascarXprt
or get shop to try and repair their handy work at no cost to me or get a new mechanic shop... also forgot to add the temp needle reached up to H and squirting out radiator fluid, not sure how much was lost. tried turning the heater all the way up and on full blast but the heater went cool...
Posted: Wed Apr 06, 2011 11:51 pm
by BlueCrush
Sounds like it might be a different issue then.
Posted: Wed Apr 06, 2011 11:55 pm
by NascarXprt
i hope it is a simple fix. i do not want to buy anything new, unless it is a belt... i hope this issue is resolvable. i hope it is what you stated Brian, though the belt should still be newish when i had them replace the belt back in the summer/fall.
Posted: Thu Apr 07, 2011 1:36 am
by star_deceiver
Take the belt off and try to turn the water pump by hand. It might be seized which would cause all of the issued you have.
Re: Squealing Belt (star_deceiver)
Posted: Thu Apr 07, 2011 5:05 am
by NascarXprt
shop may think it is the water pump.
Posted: Thu Apr 07, 2011 5:24 am
by matrixjim
what the mileage on trix?How is the coolant level.Was coolant changed out per the mfg spec?Sounds like a water pump going bad or a bad tensioner pulley.
Re: Squealing Belt (matrixjim)
Posted: Thu Apr 07, 2011 2:59 pm
by NascarXprt
the vibe has 108,xxx miles on it, bought it with 95K on it and as for coolant levels, never checked. when i had my 04 vibe, never checked coolant levels for over 5 years, then again i had 3 different engines in there.. . but when the shop looked at it, they said it looks like there was no coolant in the radiator, then again a lot was lost early in the mornin.
Posted: Fri Apr 08, 2011 3:59 am
by Water boy
Yea, I'd take the belt off and turn the various items by hand.Check the belt tensioner assembly.Once a belt has started to squeeeel a lot it is cooked.Only use a GatorBack belt.
Posted: Mon Apr 18, 2011 8:00 am
by Esteban
There are a couple of these engines affected by this TSB.
http://www.empirepao.com/tsb/T-SB-0087-09.pdf
