hankook ventus v4 es tires - how do you like them?
Posted: Fri Mar 25, 2011 1:48 pm
by wingman7000
anyone using or used hankook ventus v4 es tires? How are they for ride quality, wear and noise?
Re: hankook ventus v4 es tires - how do you like them? (wingman7000)
Posted: Sat Mar 26, 2011 3:50 am
by star_deceiver
Ride quality: Hard, firm, the way it should be!Wear: They've been on for about a week so I'll get back to you.Noise: After 4 months of studded tires I was plesantly surprised when I heard a song I liked on the stereo, decided to crank it and realized that it was blasting loud at only 1/2 volume!!!
http://forums.genvibe.com/zerothread?id=42912
Re: hankook ventus v4 es tires - how do you like them? (star_deceiver)
Posted: Sat Mar 26, 2011 9:36 am
by wingman7000
thanks. I found a set of 4 225/50/17 on craigslist for $100 with less than 3000 miles on them and picked them up today. They're obviously a little wider than the 215 stock size but look good in my opinion. We'll see how they work out. I was shocked at how unevenly worn out the bridgestone potenzas were when they got pulled off. No wonder they were so noisy on the hwy.
Posted: Sun Mar 27, 2011 11:58 pm
by wingman7000
ok so I installed the 225/50/17 ventus vr4s and they seem to be pretty nice. My speedometer is now about 3 mph slow though. I didn't think that a wider tire would cause a difference since the profile is the same as the stock 215/50/17. Even with the stock tire size my speedo was about 1 - 1.5 mph slower than my GPS. Does anyone know if the slightly larger tire cause any problems?
Posted: Mon Mar 28, 2011 1:28 am
by Notchy
That is a very common problem with Vibes it seems.
Re: (wingman7000)
Posted: Mon Mar 28, 2011 7:53 am
by Kincaid
Quote, originally posted by wingman7000 »ok so I installed the 225/50/17 ventus vr4s and they seem to be pretty nice. My speedometer is now about 3 mph slow though. I didn't think that a wider tire would cause a difference since the profile is the same as the stock 215/50/17. Even with the stock tire size my speedo was about 1 - 1.5 mph slower than my GPS. Does anyone know if the slightly larger tire cause any problems?The profile of the tire is also known as an aspect ratio - a ratio is a percent. I believe your 225/50-17 is 225mm at its widest, and the sidewall is 50% of that measurement - so, the sidewall measured from rim to the ground must be 112.5mm. The wider your tire gets the taller your sidewall gets, as long as the aspect ratio stays the same.I checked with this tire calculator:
http://www.1010tires.com/TireS...ubmitIt says the difference is only 1.51% taller overall diameter, which doesn't even approach the 3% change that seems to be the limit that triggers brake warnings on these tire calculators. If your speedo was accurate before, your speed should now be 1 mph slower at an indicated 60 mph.I also tried to find out what "brake failure" really means but could not. Obviously, there are tons of lifted trucks with ABS running around out there on humongous swamper tires.
Posted: Mon Mar 28, 2011 8:19 am
by Kincaid
wingman, see my last post here for add'l info:
http://forums.genvibe.com/zero...age=2
Re: (wingman7000)
Posted: Mon Mar 28, 2011 4:05 pm
by star_deceiver
Quote, originally posted by wingman7000 »Does anyone know if the slightly larger tire cause any problems?They might rub with the wheel cranked left or right, but I doubt it. Mine are 205-50-17's and I find the stability and traction control don't like sharp corners at speed.... so now I keep those systems off all the time. I haven't had the ABS come on yet.
Posted: Tue Mar 29, 2011 12:17 am
by wingman7000
Thanks Kincaid...thats a very helpful website
