power door locks locking on their own.
Posted: Thu Jun 26, 2003 8:59 am
by RCARLTON12
My wife called me today and wanted to know if the power door locks should be locking by theirself. She luckily had the keys and remote inher hands outside of the VIBE when she heard the doorslock , not only one but three times.I asked her if she might have hit the button and she said no. Has anyone else had this happen?
Re: power door locks locking on their own. (silverawd26)
Posted: Thu Jun 26, 2003 10:13 am
quote:Do you have the security package? If so, this will happenb. They lock on their own if you unlock the vehicle and do not get in within 10-15 seconds. Actually, it's the power package that does that, not the security package. I don't have the security package, but I do have power, and that does it...Also, if you lock the doors with the remote, and then try to manually unlock them by reaching in and unlocking it, most likely, the car will relock the door.
Re: power door locks locking on their own. (ragingfish)
Posted: Thu Jun 26, 2003 10:15 am
by yank dini
Co Sign
Posted: Thu Jun 26, 2003 12:54 pm
by NovaResource
quote:Actually, it's the power package that does that, not the security package. I don't have the security package, but I do have power, and that does it...Not true. The power package does not lock the door on it's own. You have to do it yourself. If it's locking on it's own, then you have a problem with the power locks and should get it checked out.quote:Also, if you lock the doors with the remote, and then try to manually unlock them by reaching in and unlocking it, most likely, the car will relock the door.Also incorrect.
Re: power door locks locking on their own. (NovaResource)
Posted: Thu Jun 26, 2003 1:19 pm
quote:Actually, it's the power package that does that, not the security package. I don't have the security package, but I do have power, and that does it...Not true. The power package does not lock the door on it's own. You have to do it yourself. If it's locking on it's own, then you have a problem with the power locks and should get it checked out.I was referring to the thing where if you unlock and don't get in after 15-20 seconds, it relocks itself.quote:Also, if you lock the doors with the remote, and then try to manually unlock them by reaching in and unlocking it, most likely, the car will relock the door.Also incorrect.I wrote that one wrong too. If you lock the doors with the remote, then reach in and try to use the power lock button, the button will not work. However, you can still manually release the locking mechanism. My apologies.
Posted: Thu Jun 26, 2003 2:36 pm
Mine definitely does that.
Posted: Thu Jun 26, 2003 3:26 pm
by Vibe Rater
A car that locks itself? That could be trouble.
Posted: Thu Jun 26, 2003 9:32 pm
by NovaResource
quote:I was referring to the thing where if you unlock and don't get in after 15-20 seconds, it relocks itself.Ah, yes, you're right. If you unlock the doors with the fob but don;t open a door with 15 seconds it will relock itself. I did forget about that option.quote:If you lock the doors with the remote, then reach in and try to use the power lock button, the button will not work. However, you can still manually release the locking mechanism.Yes, that works as well. If you lock the car with the fob (with all the doors closed) or if you lock the doors with the electric switch on the door (with a door open) and then close the door the electric door buttons do not work.
