No left side sound
Posted: Sun Feb 13, 2011 4:05 pm
by Mr Magoo
I have a problem with the speakers on the left side of the car, front and back. I basically have a very weak signal. If I press my ear to the front left I can hear a little sound. I'm not sure anything is coming from the back. Original stereo had this issue and now the new one does too. Any ideas?
Posted: Mon Feb 14, 2011 9:27 am
by DoubleBaril
Do you have the moon & tunes stock amp? Maybe there's a problem with the left output on the amp?
Re: No left side sound (Mr Magoo)
Posted: Tue Feb 15, 2011 2:23 am
by Sublimewind
Quote, originally posted by Mr Magoo »I have a problem with the speakers on the left side of the car, front and back. I basically have a very weak signal. If I press my ear to the front left I can hear a little sound. I'm not sure anything is coming from the back. Original stereo had this issue and now the new one does too. Any ideas? What do you mean old and new? New aftermarket stereo or factory replacement? I would think it's a problem AFTER the unit, if it's done it with 2 different units..
Re: No left side sound (Sublimewind)
Posted: Tue Feb 15, 2011 5:24 pm
by Mr Magoo
It is a factory replacement. Definitely after the unit. Bad ground? Never been wrecked.
Posted: Tue Feb 15, 2011 9:04 pm
by DoubleBaril
Maybe the speaker wires themselves are grounded out somewhere.
Posted: Tue Feb 15, 2011 9:09 pm
by Sublimewind
hard to say.. about the only thing I could say would be to remove the HU and remove the speakers from the left side and ohm out the lines with a meter.. maybe there is a pinch on the wire?
Posted: Tue Mar 08, 2011 10:29 am
by Danielvis
I am having the same problem w/ 04 Vibe. No bass and very little volume from left speakers. Any luck on a fix?
Re: (Danielvis)
Posted: Sun Mar 27, 2011 9:15 am
by Mr Magoo
Well, it turns out both speakers were bad. Replaced both and now all is well.
