Has ANYONE gotten their PCM replaced under GM's half arsed 'recall'?
Posted: Thu Jan 27, 2011 10:38 am
by Gandalf
Because I KNOW that I sure can't: GM claims there isn't 'really' an 'actual' recall on my car, so they don't have to replace the PCU.Yet, Toyota is actively following their 'actual recall', and replacing those defective POC Delphi PCU's.I have come to the conclusion that GM is ACTIVELY trying to AVOID replacing ANY of the KNOWN defective PCU, as much as they can get away with.And now, they are 'denying' there IS a 'recall' on the Vibe PCU's I got that in a phone call to GM just TODAY.I keep reading about the PCU's failing, and GM TRYING to avoid even replacing them at no charge, unless people kick up a stink.I THINK that GM INTENDS to NEVER ACTUALLY RECALL the Vibes with the defective PCU's, and FULLY INTENDS TO weasel out of their responsibility to fix them en mass, as they SHOULD...and like Toyota actually IS DOING. And, this pisses me off.
Re: Has ANYONE gotten their PCM replaced under GM's half arsed 'recall'? (Gandalf)
Posted: Thu Jan 27, 2011 10:53 am
by BadBrew
Well actually here in Canada, the recall has been filed at Transports Canada (government) here:http://wwwapps.tc.gc.ca/Saf-Se...pg=-1I guess GM can't deny it, or skip this recall. I guess there's an equivalent site in the US...
Posted: Thu Jan 27, 2011 11:12 am
by KITT222
My step-moms Corolla was recalled, and she just got a letter of notice, and nothing else. It said Toyota would notify her once the part was ready to be installed. It isn't a GM issue, and one can assume GM doesn't want to take responsibility for Toyota's faulty parts. Either that, or the person you talked to knows nothing about it. I'd say you should go into a Toyota dealer with the letter you got, if you got a letter, or give them your situation and they should handle it pretty well.
Posted: Fri Jan 28, 2011 6:01 am
by scherry2
I got it replaced on my 03 way back in 05.
Re: Has ANYONE gotten their PCM replaced under GM's half arsed 'recall'? (scherry2)
Posted: Fri Jan 28, 2011 6:04 am
by silverbullet
Quote, originally posted by scherry2 »I got it replaced on my 03 way back in 05. I did not know the 03 was affected by this. I have an 03 and I don't think the previous owner had any recall work done. I'm gonna have to look and see if I can find any recalls I. Am affected by.
Re: Has ANYONE gotten their PCM replaced under GM's half arsed 'recall'? (silverbullet)
Posted: Fri Jan 28, 2011 7:19 am
by KITT222
The recall is only on the 05-08 Vibes/Matrixs/Corollas. The 03-04 Vibes are fine. As far as I know....
Posted: Fri Jan 28, 2011 10:21 am
by Salsa Guy
Excludes 05-06 AWD Vibe/Matrix Also
Posted: Fri Jan 28, 2011 10:40 am
by ou.grizzly
Quote, originally posted by Gandalf »Because I KNOW that I sure can't: GM claims there isn't 'really' an 'actual' recall on my car, so they don't have to replace the PCU.Yet, Toyota is actively following their 'actual recall', and replacing those defective POC Delphi PCU's.I have come to the conclusion that GM is ACTIVELY trying to AVOID replacing ANY of the KNOWN defective PCU, as much as they can get away with.And now, they are 'denying' there IS a 'recall' on the Vibe PCU's I got that in a phone call to GM just TODAY.I keep reading about the PCU's failing, and GM TRYING to avoid even replacing them at no charge, unless people kick up a stink.I THINK that GM INTENDS to NEVER ACTUALLY RECALL the Vibes with the defective PCU's, and FULLY INTENDS TO weasel out of their responsibility to fix them en mass, as they SHOULD...and like Toyota actually IS DOING. And, this pisses me off. What model year and trim level is your Vibe?
Posted: Fri Jan 28, 2011 3:25 pm
by Gandalf
Mine is an '05 base FWD automatic.DEFINITELY 'in' the recall.I just want to get it fixed BEFORE the PCU craps out on me when I'm on the freeway doing 60 MPH.
