Need help identifying cold air intake
Posted: Sat Jan 22, 2011 7:01 pm
by Whatisthistube
Hi, hopefully this is in the right place:I bought an '05 Vibe recently and the day after I bought it, the CEL came on. So I took it back to the dealership and they replaced the aftermarket cold air intake that was in it with a standard one and left the aftermarket one in the trunk for me. Not being much of a tuning enthusiast, and hoping to cut back on CEL's, I want to sell it. Trouble is that it doesn't have a logo or any other markings on it to clue me in on what brand it is. Was hoping someone here might recognize it or point me in the right direction. All I have is that the MAF sensor is a Toyota 22204-00030 B TN197400-2120, and these pictures (excuse the horrific MS Paint-job).Also, where would you recommend selling it? On this site or Ebay? Thanks in advance.
Re: Need help identifying cold air intake (Whatisthistube)
Posted: Sat Jan 22, 2011 9:42 pm
by keithvibe
cosmo, the 05-08 intakes were two piece's.
http://www.cosmoracing.com/pro...=1118remove that plastic insert in the filter.Also Remove the MAF sensor that is still in that CAI... that is worth more than anything.Those will run 250 bucks alone.So unless the dealer gave you a new MAF sensor or the photo was taken just before it was remove and added to the new intake then I would deff remove it.Used CAI go for about 80bucksYou may still get CEL's even with the new CAI.IF you really want to help prevent it switch to a Short ram intake
Posted: Sat Jan 22, 2011 10:51 pm
by Salsa Guy
Yep looks like a cosmo.
Posted: Sun Jan 23, 2011 12:52 am
by keithvibe
I have some issues with the posts1. most dealers will rape you, and tell you you need xyz part when you really don't2. did the dealer tell you, you needed a new MAF sensor for the new factory intake? If so what did they charge you for it?ignore my last statement in my previous post. I was under the impression that the dealer installed a different CAI... but I read your post one more time and now I'm under the impression they installed the factory intake.
Posted: Sun Jan 23, 2011 1:09 am
by Salsa Guy
Also I don't think the Cosmo is worth $250 maybe with the MAF sensor. Does the CAI have another port between the MAF and throttle connection?
Re: (rmckinjr)
Posted: Sun Jan 23, 2011 2:41 am
by lovemyraffe
The Cosmo CAI is not worth $250. You can buy it new for ~$120. Try to clean the MAF before buying a new one.
Re: (rmckinjr)
Posted: Sun Jan 23, 2011 2:44 am
by keithvibe
Quote, originally posted by rmckinjr »Also I don't think the Cosmo is worth $250 maybe with the MAF sensor. Does the CAI have another port between the MAF and throttle connection? read my post again.... the maf 250 if bought new (aprox)the intake 80
Re:
Posted: Sun Jan 23, 2011 7:42 am
by Whatisthistube
Hey, thanks for your replies. Awesome for identifying it.What happened with replacing the CAI and MAF was that I bought the car and the Toyota dealership had scheduled to replace the CAI and MAF that was in it with factory parts, but had sold it to me first and let me drive off the lot without doing the work. I guess they didn't want to sell it with aftermarket parts. Then the CEL came on and I brought it back a few days later where they replaced the CAI and MAF without charging me anything for it.Are the plastic inserts meant to be removed when installed? Or doesn't it matter?
Posted: Sun Jan 23, 2011 8:20 am
by Salsa Guy
If your are going to sell it, keep it together (the CAI that is). Take the MAF off and keep the screws! I'm not sure what a used OEM MAF goes for but a new aftermarket is about $80
Posted: Sat Feb 19, 2011 11:10 am
by Whatisthistube
Any ideas where I could sell the CAI and MAF? I see you need 40 posts here, and the ones on Ebay don't really sell a lot of the time. Should I try a local used auto parts store? I'm not trying to break the bank here, just want to get something for them. Any ideas?
Re: (Whatisthistube)
Posted: Sat Mar 12, 2011 1:53 pm
by jhessling
Do you still have the intake? I may be interested in buying it off of you?
Re: (jhessling)
Posted: Sat Apr 09, 2011 12:35 am
by Whatisthistube
Yep, still have it. I'll send you a message.
