Suspension noobie question
Posted: Fri Jan 14, 2011 10:51 pm
by Gekko
Noobie here around these cars. I have an 03 Vibe. Will a set of lowering springs from a 2005 toyota corolla fit on my 03 vibe?
Re: Suspension noobie question (Gekko)
Posted: Mon Jan 17, 2011 1:55 am
by ramenboy...
Quote, originally posted by Gekko »Noobie here around these cars. I have an 03 Vibe. Will a set of lowering springs from a 2005 toyota corolla fit on my 03 vibe?better to match to a matrix than corolla. the springs should fit, but i think the spring rate might be different because the vibe's a heavier car than corolla...
Re: Suspension noobie question (ramenboy...)
Posted: Mon Jan 17, 2011 3:26 am
by vibedrivermatt
yeah I would try to check which brand springs the corolla has and then look at some charts from that manufacturer to see if the part number matches the 03 vibe. I just checked the TRD springs and theres different p/n's for 03 corolla and matrix/vibe. That was just TRD though maybe theres other aftermarket springs can be used on both?
Posted: Mon Jan 17, 2011 8:15 am
by BlueCrush
Quote, originally posted by Gekko »Noobie here around these cars. I have an 03 Vibe. Will a set of lowering springs from a 2005 toyota corolla fit on my 03 vibe?Yeah, the Corolla has different weight ratios and spring rates. I would look at getting springs that were made for the Vibe or Matrix.
Posted: Tue Jan 18, 2011 3:19 am
by audiovibe
They will fit but the money you will spend in replacement struts would kill you in the end. You could probably in the end cause damage to where the strut mounts over time if using the rolla springs. The only benefit would be the ability to have a lower stance. However the cons outweigh the pros by a mile. Your car could become very unpredictable.
