snapped handbrake cable?
Posted: Sat Jan 08, 2011 10:16 pm
by bassplayaz06
so i replaced my warped rear rotors yesterday, and suddenly the right rear handbrake drags, and the left doesnt engage at all. i followed the service manual posted on here for adjusting them and it did nothing. i asked a guy at church that owned a celica, and he says my left cable has snapped. possibly?
Posted: Sat Jan 08, 2011 11:10 pm
by Sublimewind
Being a manual it's get's used more than an auto.. Either way, if it doesn't get used enough, it shouldn't get used because the cable rusts and well, there is only a little spring to make it return.. Do you use it a lot? If so, it's quite possible..Possible one of the nibs on the end of the cable slipped.. Dig in... If you pull the center console and look at the balance in there (between the 2 cables) it should be easy to see if one is pulled more than the other... either way, your going to have to dig into the brakes to see..
Re: (Sublimewind)
Posted: Sun Jan 09, 2011 12:15 am
by bassplayaz06
yeah, i use it everytime i park. so i guess it just wore out. im gonna be under it checking it out today if o'm not helping a friend install control arms on his audi.
Posted: Sun Jan 09, 2011 3:12 am
by Salsa Guy
Yea I had one "stretch out" on a mini van. Had to have it replaced. Normally it isn't that big of a job it's just a matter of confirming it's bad and getting all linkages are set properly. Goodluck!
Re: snapped handbrake cable? (bassplayaz06)
Posted: Sun Jan 09, 2011 5:43 am
[QUOTE=bassplayaz06]so i replaced my warped rear rotors yesterday, and suddenly the right rear handbrake drags, and the left doesnt engage at all. QUOTE]I subscribe to cause and effect, and I'd assume that the cause was the work done on the rear brakes. Having the cable suddenly drastically stretch by the same day you reworked the brakes is too big of a coincidence. I recommend checking the one that drags to make sure you put it all back together correctly. Check the other one also, to make sure the parking brake cable is hooked up
Re: snapped handbrake cable? (joatmon)
Posted: Sun Jan 09, 2011 6:57 am
by lovemyraffe
Quote, originally posted by joatmon »I subscribe to cause and effect, and I'd assume that the cause was the work done on the rear brakes. Having the cable suddenly drastically stretch by the same day you reworked the brakes is too big of a coincidence. I recommend checking the one that drags to make sure you put it all back together correctly. Check the other one also, to make sure the parking brake cable is hooked upI'll agree with joatmon. Go back and double check your work.
Posted: Sun Jan 09, 2011 7:34 am
by bassplayaz06
i got it all fixed. just nor adjusted right. didnt snap. the grinding noise im hearing is the plate behind the brake assembly. it got bent at the top somehow and now the sides drag against the back of the inside rim of the rotor.
Posted: Sun Jan 09, 2011 9:42 pm
by Salsa Guy
Quote, originally posted by joatmon »[QUOTE=bassplayaz06]so i replaced my warped rear rotors yesterday, and suddenly the right rear handbrake drags, and the left doesnt engage at all. QUOTE]I subscribe to cause and effect, and I'd assume that the cause was the work done on the rear brakes. Having the cable suddenly drastically stretch by the same day you reworked the brakes is too big of a coincidence. I recommend checking the one that drags to make sure you put it all back together correctly. Check the other one also, to make sure the parking brake cable is hooked upYou are correct about the cause & effect. That's why I put in "confirm it's bad". Glad it was a simple fix!
