Rear washer fluid works, front does not?
Posted: Mon Dec 06, 2010 1:49 am
by surbey
I want to start by saying I love Genvibe. I've gotten alot of great assistance here in the past; I hope I can get another :D.I noticed this last week that my front washer fluid no longer works. The blades go but fluid does not come out. The back one, however, works. Do the front and rear lines use the same pump? Any thoughts?
Re: Rear washer fluid works, front does not? (surbey)
Posted: Mon Dec 06, 2010 2:12 am
welcome to genvibewhat year Vibe? I don't know about the 09/10 set up, but on the 03-08, front and rear have separate washer pumps, but both washer pumps get power from the same fuse (if the rear works and the front doesn't then its not a fuse problem)
Posted: Mon Dec 06, 2010 2:19 am
by scherry2
the '03 manual says they are separate pumps. which would cover the old body style i'm sure. the front pump is located in the side of the plastic reservoir the rear is in the front of the reservoir. have someone push the lever while you listen at the pump for a humming noise.
Posted: Mon Dec 06, 2010 2:25 am
by surbey
it's a 2004. I'll try that. I was worried it was the pump or it was blocked. Thanks guys.
Re: Rear washer fluid works, front does not? (scherry2)
Posted: Mon Dec 06, 2010 3:55 am
by scherry2
you probably can see it from underneath. with sheild moved
Posted: Mon Dec 06, 2010 4:00 am
by tribalman
if you want more instructions do a search. i have a writeup on how to change the pumps out. 03-08 model.
Re: Rear washer fluid works, front does not? (tribalman)
Posted: Mon Dec 06, 2010 6:44 am
by midnighthunder89
Have you checked the fluid i know if mine gets to low the back will still work but the front wont.
Posted: Fri Dec 10, 2010 10:18 pm
by surbey
your writeup was AWESOME tribal, thanks for the assistance. I've now got another issue.I swear, this car is falling apart.
Posted: Tue Dec 09, 2025 1:58 pm
by Vogel
My front stopped working and there are 2 seperate moters so for now I just switched hoses from back pump to use as front pump took 5 mins. I will be replacing the broken 1 eventually but switching was just a quick fix for me Here's a link for instructions on an easy way to swap wiper motors. https://www.youtube.com/watch?v=o6eYxO6znuM
