Mass Flow Air Sensor
Posted: Fri Nov 12, 2010 1:34 am
by Slide
My mechanic said I need to replace, but maybe clean my mass flow air sensor. Can anyone tell me about this job?My 2004 Vibe has 261,000 miles and going strong.
Posted: Fri Nov 12, 2010 1:42 am
by rAERRK
Re: Mass Flow Air Sensor (Slide)
Posted: Fri Nov 12, 2010 1:50 am
by ehoff121
Very easy to do and it takes about 10 minutes (if you include drying time).Remember to disconnect the negative battery terminal prior to disconnecting the MAF sensor.
Re: Mass Flow Air Sensor (ehoff121)
Posted: Fri Nov 12, 2010 10:54 am
by Mark
Quote, originally posted by ehoff121 »Remember to disconnect the negative battery terminal prior to disconnecting the MAF sensor.Just curious here, but why? I clean mine twice a year when I replace the air filter, but I don't disconnect the battery cable when I do. Should I be? Why? What's the point/benefit of doing that? Or is that only recommended when the MAF is dirty enough to cause a problem? I did disconnect for 20 min or so to clear the ECM the first time I cleaned it, but I haven't bothered since then.
Re: Mass Flow Air Sensor (Mark)
Posted: Fri Nov 12, 2010 11:01 am
by BlueCrush
Quote, originally posted by Mark »Just curious here, but why? I clean mine twice a year when I replace the air filter, but I don't disconnect the battery cable when I do. Should I be? Why? What's the point/benefit of doing that? Or is that only recommended when the MAF is dirty enough to cause a problem? I did disconnect for 20 min or so to clear the ECM the first time I cleaned it, but I haven't bothered since then.There is no benefit, really, but it will prevent a possibility of a short occurring that will fry your MAF. It is just a precaution.
