Mass Flow Air Sensor
Slide
Post by Slide »
My mechanic said I need to replace, but maybe clean my mass flow air sensor. Can anyone tell me about this job?My 2004 Vibe has 261,000 miles and going strong.
rAERRK
Post by rAERRK »
ehoff121
Re: Mass Flow Air Sensor (Slide)
Post by ehoff121 »
Very easy to do and it takes about 10 minutes (if you include drying time).Remember to disconnect the negative battery terminal prior to disconnecting the MAF sensor.
Mark
Re: Mass Flow Air Sensor (ehoff121)
Post by Mark »
Quote, originally posted by ehoff121 »Remember to disconnect the negative battery terminal prior to disconnecting the MAF sensor.Just curious here, but why? I clean mine twice a year when I replace the air filter, but I don't disconnect the battery cable when I do. Should I be? Why? What's the point/benefit of doing that? Or is that only recommended when the MAF is dirty enough to cause a problem? I did disconnect for 20 min or so to clear the ECM the first time I cleaned it, but I haven't bothered since then.
BlueCrush
Re: Mass Flow Air Sensor (Mark)
Post by BlueCrush »
Quote, originally posted by Mark »Just curious here, but why? I clean mine twice a year when I replace the air filter, but I don't disconnect the battery cable when I do. Should I be? Why? What's the point/benefit of doing that? Or is that only recommended when the MAF is dirty enough to cause a problem? I did disconnect for 20 min or so to clear the ECM the first time I cleaned it, but I haven't bothered since then.There is no benefit, really, but it will prevent a possibility of a short occurring that will fry your MAF. It is just a precaution.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
