				Moonroof Rattle?
				Posted: Mon Nov 08, 2010 1:41 am
				by pjh
				The moonroof on my 2003 vibe rattles when I go over bumps.  Anyone had this, or know how to fix it?
				Re: Moonroof Rattle? (pjh)
				Posted: Mon Nov 08, 2010 3:54 am
				by ehoff121
				First thing I'd do is a visual inspection of the channel. Open the window all the way and then look from above for any debris.I found two mystery rubber pieces in my '05, about 1/4" long by 1/8" thick(rectangular) and they rattled around...
				Posted: Mon Nov 08, 2010 5:07 am
				by pjh
				Ok, after a bit of a closer inspection it seems the rattle is coming from just in front of the moon roof, above where the sun visor sits.  If I push up on the ceiling in that area the noise goes away.  Maybe I need to take down the ceiling in that area, or just try to shove some foam in there from the moon roof?
				Posted: Fri Nov 12, 2010 12:50 am
				by Chango
				Mine only does it when the visor is open and the moon roof closed.  If I open the roof it goes away.  If I close the visor it goes away.
				Re:  (Chango)
				Posted: Fri Nov 12, 2010 6:25 am
				by pjh
				Unfortunately, this is the configuration in which I drive 95% of the time.
				Posted: Fri Dec 10, 2010 7:46 am
				by the_sarge
				I had the same thing.  I have my headliner out right now working on a moonroof leak. I found one of the mounting nuts on the moonroof assembly itself loose.  I never would have found it without taking the headliner down though.  That's not too hard a job, there's a post on here telling how to do it step by step.
				Posted: Fri Dec 10, 2010 7:49 am
				by pjh
				Thanks, I'll have to get around to looking into that soon.
