Clear sticker thing on rear door bottom
Posted: Sun Aug 29, 2010 9:09 am
by Unique Witty Name
Hi,not sure if this is the place to post this, but I noticed a clear sticker on the bottom part of the rear doors that I am assuming protects the paint from stone chips?Anyways, one of them is peeling and discolored and I am wondering whether there are replacements available or if I should just peel it off and hope that the paint doesnt get damaged more than it already is?Thanks
Re: Clear sticker thing on rear door bottom (Unique Witty Name)
Posted: Sun Aug 29, 2010 11:25 am
by 06pvibe
This sounds like a clear paint protection material I am familiar with, but pictures would help. Are you saying that this material is on the rocker panels?Either way, I would replace it if I were you. Try
http://www.lamin-x.com for strips and /or bulk material.
Re: Clear sticker thing on rear door bottom (06pvibe)
Posted: Sun Aug 29, 2010 9:58 pm
by Whelan
I have it on my Matrix as well. It is for protecting against any rocks or debris that could get thrown up by the front wheels. It is just a small patch and mine is starting to peel as well. Until it gets worse I will then just pull it off, but for now it's only a tiny bit.
Posted: Mon Aug 30, 2010 12:25 am
by kostby
The 'clear sticker thing' was factory-applied to plastic lip of the rear doors of '03-'08 cars with the 'monotone package', an extra-cost option where the lower body is painted to match the upper body, instead of gray lower-body cladding.
