Remote for door locks stopped working
Posted: Mon Jun 21, 2010 8:35 pm
by bertherr
One of my two remotes for the door locks stopped working for my 2005 AWD Vibe. The battery is good in this remote. None of the buttons will do anything to the car.Do I have to replace it? Can I test it somehow?Thanks, Bert
Posted: Wed Jun 23, 2010 11:42 am
by audiovibe
How did you test the battery? Did you drop the remote in a puddle by any chance? Have you tried to reprogram the fob?
Re: Remote for door locks stopped working (bertherr)
Posted: Wed Jun 23, 2010 7:26 pm
by djkeev
Sorry to insult, but is the battery in correctly? They do have a + and a -The two sides are awfully similar and the battery CAN be inserted upside down.If it isn't this, I'll go with the post above, what unusual things happened to the FOB?Dave
Re: Remote for door locks stopped working (djkeev)
Posted: Wed Jun 23, 2010 8:45 pm
by bertherr
This remote was not dropped into water or anything like that. It just stopped working.I tested the battery with a voltmeter. I also tested my other remote's battery with a volt meter. They both showed a little over 3 volts which are marked on the battery. I even tried switching the batteries between the remotes. No changes.I did not try reprogramming the remote because I do not know how. I was hoping that someone would post this procedure for me so I could try that.Thanks, Bert
Posted: Wed Jun 23, 2010 11:36 pm
Quote, originally posted by bertherr »I did not try reprogramming the remote because I do not know how. I was hoping that someone would post this procedure for me so I could try that.They did (seven years ago ) http://forums.genvibe.com/zerothread?id=1437Quote, originally posted by NovaResource »Don't be afraid to add the new remote. Here's how to do it without deleting the old codes:http://forums.genvibe.com/zero...e.jpg
Re: Remote for door locks stopped working (joatmon)
Posted: Thu Jun 24, 2010 1:51 am
by bertherr
I'll give the method for adding a remote, in the last link, a try tonight.If I were to use the method where you can program up to 4 remotes, would it matter which remote I started with? Also, is this doing anything to the key itself? Does the key have a chip in it?Thanks for the links, Bert
Posted: Thu Jun 24, 2010 6:10 am
by bertherr
I went through the process for adding a remote. The car did respond to all of the key and door cycles by flashing the lights and lock/unlock the doors. But, it did not respond to the required button pushing on the remote. I guess something has fried in the remote. BTW, the other remote still works. Bert
Posted: Thu Jun 24, 2010 8:36 am
by SlammedNiss
Mine recently quit working as well. Thought it was the battery (it's the original battery from 8 years ago) but didn't work even with a new battery.. Haven't tried reprogramming yet.
Re: (SlammedNiss)
Posted: Thu Jun 24, 2010 8:20 pm
by Blueridge9
Sorry to read about your remote not working. When I bought my Vibe used it did not have a remote. I bought one for a Toyota Matrix and programmed it myself for the Vibe and it works great. I even left it in my clothes and put it thru the washing machine once (duh) and it STILL worked. Here's where I got it: http://www.carandtruckremotes.com.
Re: (Blueridge9)
Posted: Fri Jun 25, 2010 12:10 am
by bertherr
I just ordered one myself earlier today off of eBay. Thanks, Bert
Re: (bertherr)
Posted: Wed Jul 07, 2010 8:04 am
by bertherr
FYI, the remote I purchased from ebay programmed perfectly. Bert
