Air conditioning trouble, please help!
Posted: Tue May 25, 2010 1:17 am
by idmaestro
ok here's the low-down on the trouble I'm having:'04 vibe, 80k milesair blows hard, but is warm, about the same as the outside tempplenty of refrigerant (40 psi,) no leakscompressor cycles on and off properlythis problem began suddenly, not graduallyruled out relay switch and fusesanyone have any ideas, tips, or suggestions? I don't want to spend a fortune on parts that I don't need...
Re: Air conditioning trouble, please help! (idmaestro)
Posted: Tue May 25, 2010 10:44 am
by Bikerscum
Well, if everything is as you say.... AC system seems to be ok, I would suspect the ductwork.... a door/bypass/cutoff/whatever is not letting the cold air into the ducts. Broken cable, that kinda thing. Good luck.
Posted: Tue May 25, 2010 8:19 pm
by djkeev
If you put it on defrost and set the temp low, do you get cool air blown onto the windshield??
Posted: Tue May 25, 2010 10:04 pm
first thing I'd do would be to rule out the problem discussed in
http://forums.genvibe.com/zerothread?id=1315
Posted: Tue Jun 08, 2010 1:08 pm
by fss106
I'd bet money its your a/c compressor clutch-- seems to be a reoccurring problem around here.
http://forums.genvibe.com/zerothread?id=41023
