More from SC?
Posted: Tue Mar 09, 2010 3:34 am
by 04chargedvibe
Ok so im not a big guru about what to do and what to change to an engine to give it more punch. But if someone could point me in the direction i can usualy get it done. I was wondering if there are some things i could do/add/improve to help out and give the SC more kick, or the engine in general get more kick. any ideas?
Posted: Tue Mar 09, 2010 3:36 am
by northvibe
you can go to a smaller pulley, get meth to help cool it, tuning solution, ported exhaust manifold, air intake.
Re: (northvibe)
Posted: Tue Mar 09, 2010 3:41 am
by scherry2
lighter pulleys
Re: (northvibe)
Posted: Tue Mar 09, 2010 7:11 am
by keithvibe
Quote, originally posted by northvibe »you can go to a smaller pulley, get meth to help cool it, tuning solution, ported exhaust manifold, air intake.^^^this
Re: (keithvibe)
Posted: Tue Mar 09, 2010 9:31 am
by 04chargedvibe
Quote, originally posted by northvibe »you can go to a smaller pulley, get meth to help cool it, tuning solution, ported exhaust manifold, air intake.ok so if i were to go through this which pulleys would you guys recommend?
Re: More from SC? (04chargedvibe)
Posted: Wed Mar 10, 2010 4:36 pm
by jarmstrong22
give it a more aggressive tune or change the pulley size, bigger, injectors or a cat back exahaust. If you don't have a CAI that may help as well.
Posted: Thu Mar 11, 2010 2:52 am
by northvibe
crap I havent looked into the kit for so long... I dont want to give you bad numbers but I think its like low 2" range.Also look into the "5th" injector.
Re: (northvibe)
Posted: Thu Mar 11, 2010 6:31 am
by keithvibe
i'm 90% sure it's a 2.3ditch the fifth injector crap and just get xrs/gt injectors
Posted: Sat Mar 13, 2010 10:18 pm
by sikvibe
Yeah, mine came with the 2.4" pulley, there's a guy @ the matrix site that put on a small aluminum pulley with a diy install..but didn't say where he got it or how much..I looked on vortecs site and there smallest is the 2.4 looks like I'm gunna have to make some calls.Also the fifth injector kinda does suck, It either runs slightly lean or is always just dumping tons of fuel, the slightly lean is porbably because I'm at 5000 feet, but I'm sure the dump is from the fifth. Once I get some mulla saved I'm going to switch to the xrs injectors, but might leave the fifth untill I get an egt gauge.Does anyone now the boost numbers on this stock charger set up?
Posted: Sat Mar 13, 2010 10:21 pm
by sikvibe
Oh yeah, one more thing..stock my gas mileage was 32..after rims, tires, and charger I'm down to an awful 25..gotta pay to play i guess, eh?
Re: (sikvibe)
Posted: Sat Mar 13, 2010 11:41 pm
by keithvibe
stock psi is 7-8 sometimes will peak as high as 9yea gas mileage will take a huge hit,not to mention your now running prem gas instead of regular.
Posted: Sun Mar 14, 2010 8:02 am
by northvibe
honestly you'd probably see a increase in mileage if you didnt drive "hard" and/or got a aftermarket tune as well. My SS/ms3 got 24 city because I drive hard and 33-35 hwy if I took it easy, but hell with FI how do you?! hahah
Re: (northvibe)
Posted: Sun Mar 14, 2010 8:45 am
by DiveNut
Quote, originally posted by northvibe »honestly you'd probably see a increase in mileage if you didnt drive "hard" and/or got a aftermarket tune as well. True, I routinely get 29 MPG with my Vibe...95% of my driving is stop and go, rush hour traffic. Average 32-33 MPG on the highway when taking long trips. The key is keeping my foot off the loud peddle. (which is not always easy to do! )
