new HU install
Posted: Wed Mar 03, 2010 4:22 pm
by mr. freeze 04
Just installed a Valor DTS-603W HU in my 04 base, and well, let's just say everything doesn't match up real well. I'm a USAF machinist, so i'm going to fab my own trim ring to fill in the gaps, will post pic after i get it programmed and cut out.
Re: new HU install (mr. freeze 04)
Posted: Wed Mar 03, 2010 4:37 pm
by Blanco_Diablo
Can't wait to see it when you are done
Posted: Fri Mar 05, 2010 8:16 am
by 07vibegxp
hey man how much will you charge to make one for a 07, we have a kenwood double din, and there is a gap i dont like as well... i was thinin fiberglass a custom one, but if you can charge a decent cheapness lol i wouldnt mind one from you
Re: (07vibegxp)
Posted: Sun Mar 07, 2010 4:35 pm
by mr. freeze 04
let me get this one done up first, i'm sure it'll take a couple attempts to achieve my desired result.
Posted: Sun Mar 07, 2010 9:46 pm
by bigdaddyjosh
Mine doesnt match up either. The radio is a bit to wide so it sits recessesed behind the trim ring. I was thinking of dremeling the surrounds on the plastic trim. Submit some pics when you are complete and maybe Ill find some motivation to do it myself. Thanks.
Re: new HU install (bigdaddyjosh)
Posted: Thu Mar 18, 2010 8:09 pm
by mr. freeze 04
Quick update. After watching how the screen moves as it motors down, i'll probably have to take a simpler approach. The distance between the HU and the factory trim piece goes from about 1/4" to under 1/16". P.S. have new door speakers on the way 4 Alpine SPS-600
Posted: Tue Mar 23, 2010 12:08 am
by mr. freeze 04
figured a picture might help out some.You can see the slight damage my basket endured during install... had to bend it at the corners then re-expand it to "original" shape. The basket was a good 1/8" - 1/4" larger than the slot.
Posted: Wed Mar 24, 2010 4:07 am
by bigdaddyjosh
Why didnt you remove the trim panel, then install the basket and radio them reattatch the pamel? That doesnt look all that bad. Maybe im just not seeing the problem cuz of my iphone screen being small. Ill post a pic tonight of mine. Atleast your DD is flush mine is recessed behind the trim panel cuz the body of the unit is to big to fit in the hole. BTW the switch in the glove box is the DVD bypass switch
Posted: Tue Apr 13, 2010 8:55 pm
by mr. freeze 04
finally got around to programming out my surround, these are just concept drawings. i'll need to take full measurements for my final piece.
