DEAD ELECTRICALS but starts and runs because of reversed polarity jump start
Posted: Sat Feb 27, 2010 4:25 pm
by Bawhp1000
HHHHHHEEEEEELLLLLLLLPPPPPPPPP!!!I did the most stupid thing today and put the jumper cables reversed!!!I put a new battery and the car starts and runs fine,but nothing else works!!!NO:head/dome/dash lights, power windows/locks, radiowhat do i do???2004 VIBE AWD AUTOMATICTHANKS IN ADVANCE TO EVERYONE HERE AT GENVIBE!!!
Re: DEAD ELECTRICALS but starts and runs because of reversed polarity jump start (Bawhp1000)
Posted: Sat Feb 27, 2010 9:41 pm
by scherry2
any fuses under the hood blown?
Posted: Sat Feb 27, 2010 11:57 pm
by Bawhp1000
I checked the fuse for the headligt under the hood and one relay, both seemed fine...I'm goin check the rest of the fuse under the hood and dash tonight when I get home from work.Was wondering if there's a main relay or fuse and where its located.
Re: (Bawhp1000)
Posted: Sun Feb 28, 2010 12:42 am
by Tonebalone
My daughter's boyfriend jump started her 2006 Matrix with similar results, although it no longer started. I found the 100 Amp alternator fuse blown, as well as several fuses under the dash were blown.Changed the fuses, all was well except for the melted battery terminal. BF swears up and down he didn't reverse polarity.To get to the big fuse, you'll need to pry the housing off the main electrical panel under the hood. The fuse terminals are bolted into the main power buss. The fuse itself is only about $3 at your auto parts place.Good luck!
Re: (Tonebalone)
Posted: Sun Feb 28, 2010 1:37 am
by Bawhp1000
TonebaloneI'll probablysound like a total fool,but are you refering to the fuse box by the driver side fender?I have to unbolt that?Thanks!!!
Re: (Bawhp1000)
Posted: Sun Feb 28, 2010 8:05 am
It does seem like it could be that 100A fuse, that's what it was for the guy in
http://forums.genvibe.com/zerothread?id=31390the 100A fuse is bolted into the underhood fuse block, and in such a way that you have to move the fuse block around to get to it. johnsoax had to replace his 100A fuse, he posted some info about it in
http://forums.genvibe.com/zerothread?id=16307
Posted: Sun Feb 28, 2010 3:50 pm
by Bawhp1000
THANK YOU GENVIBE!!!Found the 100A fuse, and it was indeed busted, was able to get it out with everyone's help!!!I have to say, the people in this forum are very helpful!!!Had an evo 8 before and alot of the people at the forums were haters!!!THANK YOU AGAIN EVERYONE!!!Will replace the fuse tomorrow to see if it's the only thing that broke...
Posted: Mon Mar 01, 2010 2:57 pm
by Bawhp1000
The VIBE is alive!!!That 100A fuse did it!!!I think I have to thoroughly check EVERY small fuse to make sure,but everything works again, except for my dome light...Thank you GENVIBE!!!! You guys are awesome!!!
Posted: Tue Mar 02, 2010 3:52 am
by scherry2
cool
