Seatbelt unscrewed from floor AGAIN
Posted: Sun Feb 21, 2010 3:53 pm
by 808 Vibes
I should've gotten a pic today, but was in a rush, plus it took me forever with my belly in the way to get the thing threaded a few times enough to stay screwed into the floor. Are they going to charge me for doing anything since it's off-warranty?
Re: Seatbelt unscrewed from floor AGAIN (HawaiiPontiacLover)
Posted: Sun Feb 21, 2010 6:28 pm
by scherry2
your seat belt bolt came un-threaded?
Posted: Sun Feb 21, 2010 11:37 pm
by 06pvibe
One word.... Loc-Tite, Red. (OK, so I can't count.)
Posted: Mon Feb 22, 2010 12:07 am
by scherry2
The reason i ask is GM puts an adhesive on the bolts and nuts for securing their belts in the trucks. they also use odd (triangular locking) shaped nuts for securing seats and belts. Another Toyota shortfall?
Posted: Mon Feb 22, 2010 12:16 am
her car has had a trauma or two, and at one point one of the shops probably took them out, and failed to loctite them on reinstall. Probably had to pull the belts to fix
http://forums.genvibe.com/zerothread?id=34783HPL, if you don't want to take it back to the shop that loosened them in the first place, it's worth it to have them secure, so you should either take it to another place to get them corrected, or buy a tool and some loctite. Either way, get them all checked out, make sure they are more than hand tight and with some sort of thread locking glue to keep them from working loose again.if it was probaly the result of a non-dealer repair, it wouldn't be covered under dealer warranty
Re: (joatmon)
Posted: Mon Feb 22, 2010 1:56 am
by ou.grizzly
Quote, originally posted by joatmon »her car has had a trauma or two, and at one point one of the shops probably took them out, and failed to loctite them on reinstall. Probably had to pull the belts to fix
http://forums.genvibe.com/zerothread?id=34783HPL, if you don't want to take it back to the shop that loosened them in the first place, it's worth it to have them secure, so you should either take it to another place to get them corrected, or buy a tool and some loctite. Either way, get them all checked out, make sure they are more than hand tight and with some sort of thread locking glue to keep them from working loose again.if it was probaly the result of a non-dealer repair, it wouldn't be covered under dealer warrantyYeah, it has to be from they removed all the interior pieces and repaired them... Star or torx drive right and some loc-tite should fix it...
Re: (ou.grizzly)
Posted: Mon Feb 22, 2010 4:58 am
by scherry2
the seatbelts in the trucks are tightened to 40 to 50 NM I'm sure the vibes are close to that.
Re: (scherry2)
Posted: Mon Feb 22, 2010 6:35 am
by 808 Vibes
Yes, completely unthreaded for the second time. I reached for the seatbelt yesterday and it came right off. And yes, the thought of those monkeys with crowbars and their shoddy work did enter my mind. Since it happened once before and the dealer hand-tightened it, I'll see what they say...I'll bring up the safety issue and maybe they'll have mercy on me...
Re: Seatbelt unscrewed from floor AGAIN (scherry2)
Posted: Mon Feb 22, 2010 8:36 am
by 06pvibe
Quote, originally posted by scherry2 »The reason i ask is GM puts an adhesive on the bolts and nuts for securing their belts in the trucks. they also use odd (triangular locking) shaped nuts for securing seats and belts. Another Toyota shortfall?The adhesive you mention is a thread locker, similar to Loctite. And the nuts are intentionally misshapen triangular to further insure the bolt will not loosen on its own.A little red Loctite and proper torquing should do the trick though.
Posted: Mon Feb 22, 2010 12:58 pm
by northvibe
please get it properly tightened!!! Id have them check both front seat belts...dont need to find out what happens in a accident with them lose now..
Re: (northvibe)
Posted: Mon Feb 22, 2010 2:03 pm
by Herb
Quote, originally posted by northvibe »please get it properly tightened!!! Id have them check both front seat belts...dont need to find out what happens in a accident with them lose now..+1!!!You're belting up for two so make sure that you're safe, even if it means keeping a wrench on board to check it weekly.
Re: (Herb)
Posted: Tue Feb 23, 2010 9:13 am
by 808 Vibes
OK, dealer service advisor took care of it for me for free, ratcheted it down tight. Last time the person only hand-tightened it. I'm happy, so I left and returned with a bunch of bakery goods.
