2AZ-FE?
Posted: Thu Feb 18, 2010 5:54 am
by bigdaddyjosh
I saw a TRD 2AZ-FE supercharger the other day on a Scion. And, as far as I can tell, that is the same engine in the 2.4 09Vibe. Question is, will it fit?
Re: 2AZ-FE? (bigdaddyjosh)
Posted: Thu Feb 18, 2010 9:26 am
by star_deceiver
I'm sure that it can be made to fit... some modifiaction required (as they say)!But can you get the pcm tuned???
Re: 2AZ-FE? (star_deceiver)
Posted: Thu Feb 18, 2010 11:02 am
by bigdaddyjosh
Actually, no, but they can do a pcm swap. Just a diff module is all.
Posted: Fri Feb 19, 2010 2:32 am
by northvibe
swapping a pcm from a scion to a vibe may not work. I dont know myself, has anyone tried it? So with the SC TRD for that engine they just flash the stock ecu right? is the toyota ecu not cracked to be able to be pulled off to a pc and reflashed? or what about emanage or something?
Posted: Fri Feb 19, 2010 2:49 am
by ou.grizzly
That TRD S/C was discontinued due to many issues; not worth it.
Posted: Fri Feb 19, 2010 8:22 am
by northvibe
well..it is a centrifugal supercharger..and belts can slip etc...almost like a belt driven turbo that runs off just like a normal roots blower would work. turbo would be better but a centrifugal like a procharger is just soooo easy to isntall because you dont have to do anything to the exhaust manifold. anywho... lame I really wanted to see a trd SC on a vibe :/
Posted: Wed Feb 24, 2010 2:38 am
by CoryW
http://cgi.ebay.ca/ebaymotors/...19366Trubo kit (havnt looked at it much just found it might work)Price tooks to good to be Legit
