p2716 line pressure control solenoid for transmission
Posted: Fri Feb 05, 2010 3:03 am
by uke18
Read an earlier thread on this solenid going bad. My problem is slightly different. Check engine came on and had two different freinds with computer diagnostics say this was the problem. This happened on Saturday. Sunday the light was off and have had no problem since. Experienced a couple occasions of bad shift when light was on Friday and Saturday. No problems since. Spoke to 2 tranny places and both said it could be a minor wire problem as well and to keep driving till it happens again so they can then check. Any similar problem or experience out there.Thanks in advance.
Re: p2716 line pressure control solenoid for transmission (uke18)
Posted: Mon Feb 08, 2010 9:13 pm
by Flinst0ne
This is almost exactly what happened to me. See post
http://forums.genvibe.com/zerothread?id=40156except my light stayed on. If you are under 80k miles I recommend getting it checked out as soon as you can. I was told by both the parts store and an independent mechanic that those hard shifts could damage the transmission.
Re: p2716 line pressure control solenoid for transmission (Flinst0ne)
Posted: Tue Feb 09, 2010 2:29 am
by uke18
I have a mechanic who works at a tranny service looking at it Saturday. The HARD shifts disappeared with the CE light. He is running diagnostics and checking ohms both hot and cold. Says it could be a wiring issue or a bad solenoid and this is the best way to determine. Thanks for your input.
Posted: Wed Feb 10, 2010 9:15 pm
by CoryW
The first gen vibe Has a horrible PCM, ive installed several PCM's for this condition, its best to have it diagnosed.
Re: p2716 line pressure control solenoid for transmission (CoryW)
Posted: Thu Feb 18, 2010 12:17 am
by uke18
Took it in to a tranny place who said solenoid is not the problem but the clutch had deteriorated to the point I need it rebuilt. Because of this the pressure was not operating in the proper range......now I am confused since they are talking an $1800 rebuild, to make matters worse warranty on certified used ran out 1/31/10 and they will not honor it
