Check engine code p2440
Posted: Mon Feb 01, 2010 5:34 am
by mossaball
I have been having intermitent check engine light problems for about a month or so. So I used a code reader and the cod was P2440. It means that the secondary air injection system switching valve stuck open. Im pretty sure this has to do with my CAI. However I wanted to see if this isnt or is a really problem. Also hope this helps anyone with the same problem that I had.
Re: Check engine code p2440 (mossaball)
Posted: Mon Feb 01, 2010 6:33 am
by lovemyraffe
Double check to make sure you have the code right. I'm not finding that code in my service manual.
Posted: Mon Feb 01, 2010 9:36 am
here's what I have on P2440
Attached files cip2440.pdf (89.3 KB)
