09 Vibe AWD Hatch wont lock
Posted: Fri Jan 15, 2010 9:14 pm
by Airmack
If I lock the doors from inside the car or using the remote lock on the key, the hatch does not lock. I can open it from the outside every time. Is it a switch or some thing I am missing or do I need to take it in?
Re: 09 Vibe AWD Hatch wont lock (Airmack)
Posted: Fri Jan 15, 2010 9:28 pm
Can you lock it physically with the key?If it's only using the power locks function (switch or remote) then it could be the actuator inside the hatch, or perhaps a bad connection. Since it's an 09, I'd say take it back to a dealer and get it fixed under warranty, except its always such a hassle to lose the time to have to go back to the dealer, so hopefully someone else will post up a quick and easy fix.
Re: 09 Vibe AWD Hatch wont lock (joatmon)
Posted: Fri Jan 15, 2010 9:33 pm
by Airmack
Quote, originally posted by joatmon »Can you lock it physically with the key?If it's only using the power locks function (switch or remote) then it could be the actuator inside the hatch, or perhaps a bad connection. Since it's an 09, I'd say take it back to a dealer and get it fixed under warranty, except its always such a hassle to lose the time to have to go back to the dealer, so hopefully someone else will post up a quick and easy fix.good thinking, I missed the key lock on it & that does work. But I pulled out the PDF from the GM website & it says (Lock): Press to lock all of thedoors and liftgate.
Posted: Fri Jan 15, 2010 10:55 pm
at least you knkow that part of the mechanism isn't siezed up, and you have a way to lock it until the electric method is restored.Does the switch or remote unlock the door? If so, the wires to it are probably ok. If you press the lock button, can you hear (or feel) anything happening in the hatch?
Re: (joatmon)
Posted: Fri Jan 15, 2010 11:12 pm
by Airmack
Quote, originally posted by joatmon »at least you knkow that part of the mechanism isn't siezed up, and you have a way to lock it until the electric method is restored.Does the switch or remote unlock the door? If so, the wires to it are probably ok. If you press the lock button, can you hear (or feel) anything happening in the hatch? i have not put my ear to it to check but i dont hear any thing like i do when the side doors lock. got a apt for this coming monday
Re: (Airmack)
Posted: Sat Jan 16, 2010 12:57 am
by beemerphile1
Maybe you got a Monday built Vibe that has power door locks but a hatch door with only a manual lock. Could happen, I've seen bigger goofs than that.
Posted: Mon Jan 18, 2010 10:13 am
by Airmack
it was the actuator
