Require some label help please
Posted: Wed Jan 13, 2010 12:40 am
I work at GM Canada and require some information please, looking for a 2005 to 2006 FWD automatic, need the gross vehicle weight information from the label on the inside door jam on the B pillar when you open the drivers door, it has Gross Axle Weight Frt, Rear and Gross Vehicle Weight. The GM data system does not store that info as it is considered outside supplier through joint venture with Toyota. Appreciate any help.
